I tried following the steps, I select Adobe Presenter Add In, but when I relaunch the PowerPoint still I am unable to view the Menu.
I earlier had MS Office 2003 and it worked fine. Recently I upgraded to MS Office 2007 and I cant the addin to enable.
Is there anything else I need to do??
Oh well finally I got my Addin running. I found that under the disabled addin lists but inspite of selecting it and enabling it I couldnt get it enabled.
Finally I went into the Disabled section and removed it completely and then added it again and viola it worked.
I also had this problem. I copied the DLL from C:\Program Files\Adobe\Presenter 7 to C:\Documents and Settings\myadminname\Application Data\Microsoft\AddIns. The name of the DLL is: MenuLauncher.dll
That seems to have done it.
had this problem myself. Fixed it like this:
Hi. I tried that but it didn't work for me. Only copying it to the Microsoft\Add
Ins folder worked for me.
Thanks.
As I was working on a Presenter file yesterday I ran into this problem -- all of a sudden, POOF, the AP tab was gone from my ribbon.
Thanks to the forum I was able to solve it, but I kinda had to hi-jack several of the suggestions.
First, I am working in PPT 2007 on Windows 7.
I used LisaTsabari's suggestion and copied the DLL file from the Presenter 7 folder into the Microsoft\addins. Unfortunately, my AP tab did not reappear!
Soldiering on, I read Reema Lodha and ID kyeoman's suggestions and did the following:
Deleted the "disabled" add-in. (Reema Lodha)
Then added it back using ID kyeoman's steps. (Note, Windows 7/PPT 2007 did not have a "manage" menu, but it did have a "go" button next to COM addin)
It all worked! Upon restarting PPT, I have my Adobe Presenter tab back!
Thanks to all in the forum!
Hi All,
To answer this, first we need to check if Adobe Presenter is installed on the computer system we are dealing with.
The easiest and the quickest way would be to go to Control Panel > Add/Remove Programs > Program Features and check within the list of instralled applications.
Once this is verified, launch Microsoft Power Point 2007 and click on the MS Office button on the top left.
* From the drop down, select PowerPoint options.
* Click on the Add Ins Tab on the left hand pane.
* On the bottom of this page next to 'Manage' click the drop down list to select 'Disabled Items' and click 'GO'.
* A second box would appear. On this smalll box click and highlight Adobe Presenter Com Add In from the list and click on 'Enable'.
* Close Powerpoint window and relaunch MS Powerpoint.
* You should now have the Adobe Presenter Tab available on the top menu bar for MS Powerpoint 2007.
Ashish Prashad
The trouble that I am experiencing is (on a Win 7 machine using PowerPoint 2007 via eLearning Suite 2 install,) that I never see Adobe Presenter in Powerpoint's COM Add-Ins at all. I also do not see Adobe Presenter in the "Disabled" list at all. I do not see it even after manually adding "menulauncher.dll" to the Microsoft/Add-Ins folder for every user of the machine. I have uninstalled, reinstalled, repaired then uninstalled and reinstalled Adobe Presenter but each time, I get the same results - Adobe Presenter never listed in COM Add-Ins as available or as "Disabled".
I will be out of the office starting 13/08/2010 and will not return until
31/08/2010.
If your matter is urgent, then please contact Emma Dawson on ext. 15832.
In 90 minute plus Adobe customer support call and talking with
4 different people they told us that Win 7 64bit/office 2010 and presentor 7 are not compatible. They recommend either downgrading the oprating system or office both i do not want to.
Hi Prachiak,
Adobe Presenter does works on 64-bit Windows 7 but then you have to install the Microsoft Office 2010 which is 32-bit version. I hope this will help.
Ravi
