For this installation I have to do the MultiServer install.
If you install the ColdFusion multiserver configuration or the J2EE
configuration, you can specify the directory in which to install
the .NET Integration software, which in my case is
"D:\CF8DotNetService". In this directory, the only log file is
'CF8DotNetsvc.log' and the only entry in it is from the last
install:
"09/05/2008 12:45:29 INFO: InstallService: Installed the
service ColdFusion 8 .NET Service"
In the cflogs\server.log I see the following:
"Information","scheduler-9","05/13/08","12:34:38",,"Starting
logging..."
license..."
"Information","scheduler-9","05/13/08","12:34:39",,"Enterprise
Edition enabled"
"Information","scheduler-9","05/13/08","12:34:39",,"Starting
crypto..."
"Information","scheduler-9","05/13/08","12:34:40",,"Installed
JSafe JCE provider: Version 3.6 RSA Security Inc. Crypto-J JCE
Security Provider (implements RSA, DSA, Diffie-Hellman, AES, DES,
Triple DES, DESX, RC2, RC4, RC5, PBE, MD2, MD5, RIPEMD160, SHA1,
SHA224, SHA256, SHA384, SHA512, HMAC-MD5, HMAC-RIPEMD160,
HMAC-SHA1, HMAC-SHA224, HMAC-SHA256, HMAC-SHA384, HMAC-SHA512)"
"Information","scheduler-9","05/13/08","12:34:40",,"Starting
security..."
scheduler..."
WatchService..."
debugging..."
sql..."
"Information","scheduler-9","05/13/08","12:34:43",,"Pool
Manager Started"
"Information","scheduler-9","05/13/08","12:34:43",,"Starting
mail..."
runtime..."
"Information","scheduler-9","05/13/08","12:34:43",,"CORBA
Configuration not enabled"
cron..."
"Information","scheduler-9","05/13/08","12:34:44",,"Starting
registry..."
client..."
"Information","scheduler-9","05/13/08","12:34:44",,"The
metrics service is disabled for the J2EE edition"
xmlrpc..."
"Information","scheduler-9","05/13/08","12:34:45",,"Starting
graphing..."
verity..."
archive..."
document..."
"Information","scheduler-9","05/13/08","12:34:46",,"Starting
eventgateway..."
"Information","scheduler-9","05/13/08","12:34:47",,"Starting
FlexAssembler..."
.NET..."
Monitoring..."
"Information","scheduler-9","05/13/08","12:34:49",,"ColdFusion
started"
So it *seems* like it should be chatting. When I perform a
netstat I see the ports are alive:
TCP dev0-henry:6085 dev0-henry.company.local:0 LISTENING
TCP dev0-henry:6086 dev0-henry.company.local:0 LISTENING
One change I've made is changing the original test code to
include the 'assemby' attribute such that the call is now:
<cfobject type=".NET" name="pingClass"
class="System.Net.NetworkInformation.Ping"
assembly = "C:/Net/Assemblies/system.dll">
Although this is where I've copied the framework .dll's and
the process has full rights to the directory, I get:
"Class System.Net.NetworkInformation.Ping not found in the
specified assembly list."
I can't tell if I'm getting closer or further from an answer.
Any/all help is very much appreciated. Thank you.
