NOOK HELP!Hi there, I have recently had to transfer my nook books to Sainsbury's & now have to use Adobe Digital Editions. I have downloaded the software, created an Adobe ID, authorised my computer & managed to Download some of my ebooks into Digital Editions but I am unable to transfer them to my nook. It seems I am unable to authorise my nook - when I click the settings 'wheel' all 3 options are grey-ed out. Can anyone suggest why this might be so? I have uninstalled & re-installed the software, I only opened the software after my nook was attached to my computer via usb cable & I am getting the E_IO_WRITE - Failed to write destination file error message when I try to copy the ebook. My nook is a Simple Touch with Glowlight, model number BNRV350 & I use Windows operating system. Please help!
Some reader could not authoirze ofer Digital Edition. Has you try it to authoirze over the Reader itself?
I don't know how to do that/if that is possible . . .
Every Reader has a own help Document. Have you check this?
I have checked through the nook help document & cannot find anything about authorising the machine either there or via the settings . . .
In this should contact the support of the Reader direkty. This persons shond you help in this point.
Thank you for your help
You are welcome. Good Luck.
Connect your nook - open ADE - if the nook is showing in the left panel click settings cog next to it - should show = authorise device - click on that. That should authorise your nook.
