Hi sencinas
Please note that if you are using RoboHelp HTML, you have
several different output types available.
* WebHelp
* WebHelp Pro
* FlashHelp
* FlashHelp Pro
* Microsoft HTML Help
* JavaHelp
* Oracle Help for Java
And ALL of these output types use .HTM files as the base for
topics.
When Colum asked about which type you are creating, it is
because the very type of output (as well as where you are trying to
view it) could be the issue.
I'm going to hazard a guess here and say that it's probably
WebHelp or FlashHelp. Your bit about having moved things to a new
folder seems to lend credence to that action in and of itself being
the issue. Have you tried moving things back to where they were? If
this is a single topic that is the issue, it's probably a simple
linking problem. If it works on your PC fine before you copy things
to a server, that even further substantiates things.
Cheers... Rick
