Hi all
If you know beforehand that you will want perhaps a bulleted
list nested inside an ordered list, you can accomplish it easily
using the following process.
Create your initial list, but don't number it quite yet.
Press Enter after the step where you want the bulleted text
to begin, then add the lines that will be bulleted.
Select part of the beginning line and part of the last, then
apply numbering. At this point, everything is numbered, but don't
sweat that.
Now select the section that should be bulleted and click Edit
> Move > Right. (Or click the Increase Indent icon on the
toolbar) The numbering should reset and you should have a numbered
list inside a numbered list.
Now change the inner list to a bulleted list.
Cheers... Rick
