Hi, kfielder,
Can you check your help project folder for one or more index
(.hhk) files and verify that at least one of them contains the
index keywords that you want to add to the help file? And that this
.hhk file is the one that you specify in your CHM project settings
and window definitions?
If you open the project (.hhp) file in Notepad, you should
find that the .hhk file is referenced in the OPTIONS section...
[OPTIONS]
Index file=Example.hhk
...and in the WINDOWS section:
[WINDOWS]
main=,"Example.hhc","Example.hhk", ...
The same .hhk file would normally be referenced in both
cases, but you do have the option to create multiple indexes and
associate each one with a different window.
It's necessary to create a binary index when including
keywords from both the topic files and the .hhk file, but the fact
that your topic keywords are showing up in the index suggests that
you're already creating this.
Pete
