1 Reply Latest reply on Apr 24, 2016 6:43 AM by kglad
    Need help with auto scroll/crawl of external text [AS2]
    DavesNotHere
      I'm relatively new to coding and I have run up against a problem with a task and could really use some help.
      My goal for the code is to perform the following:
      1. Load a variable amount from an external text file.
      2. Be able to switch between automatically scrolling vertically or crawl/marquee horizontally.
         (Does not need to loop, but if its simple enough to include the option that would be useful for the future)
      3. Control the speed of the scroll/crawl.
      The limiting factor is it needs to be in ActionScript 2.0 and can't be higher than Flash 8. This is due to the program the .swf is being imported into.
      I was able to get the external text in with this code:
      myData = new LoadVars();
      myData.onLoad = function()
        textBox.text = this.typeNews;
      myData.load("//.../textNews.txt");
      I have not been able to auto scroll/crawl the text without putting the textBox on a motion path and controlling the speed by adding frames. This is not ideal as this limits the amount of text to the size of the text box I create.
      I would really appreciate any help with this. Thanks!
