In Adobe Business Catalyst I've created a "hero slider" web app. (For the css framework I'm using Foundation 6). When the web page gets rendered it shows the slides dynamically. But I don't know how to show the orbit-bullets dynamically based on the number of slides in the web app.
Can this be done with liquid? If so, what should the liquid-code look like?
In the Foundation6 example, I want to trigger what is between the <nav class="orbit-bullets"> class.
Thanks for any help.
Kind regards
Carla
<body>
<pre>
<code>
<div class="orbit" role="region" aria-label="Favorite Space Pictures" data-orbit>
<ul class="orbit-container">
<button class="orbit-previous"><span class="show-for-sr">Previous Slide</span>◀︎</button>
<button class="orbit-next"><span class="show-for-sr">Next Slide</span>▶︎</button>
<li class="is-active orbit-slide">
<img class="orbit-image" src="assets/img/orbit/01.jpg" alt="Space">
<figcaption class="orbit-caption">Space, the final frontier.</figcaption>
</li>
<li class="orbit-slide">
<img class="orbit-image" src="assets/img/orbit/02.jpg" alt="Space">
<figcaption class="orbit-caption">Lets Rocket!</figcaption>
</li>
<img class="orbit-image" src="assets/img/orbit/03.jpg" alt="Space">
<figcaption class="orbit-caption">Encapsulating</figcaption>
</li>
<img class="orbit-image" src="assets/img/orbit/04.jpg" alt="Space">
<figcaption class="orbit-caption">Outta This World</figcaption>
</li>
</ul>
<button class="is-active" data-slide="0"><span class="show-for-sr">First slide details.</span><span class="show-for-sr">Current Slide</span></button>
<button data-slide="1"><span class="show-for-sr">Second slide details.</span></button>
<button data-slide="2"><span class="show-for-sr">Third slide details.</span></button>
<button data-slide="3"><span class="show-for-sr">Fourth slide details.</span></button>
</nav>
</div>
</code>
</pre>
</body>
I haven't tested this code but here is the way I would do this with web apps. Change your fields to match your web app:
<div class="orbit" role="region" aria-label="My web app slider" data-orbit>
{module_webapps id="XXXX" filter="all" resultsPerPage="10" hideEmpt
...Copy link to clipboard
{module_webapps id="XXXX" filter="all" resultsPerPage="10" hideEmptyMessage="true" rowCount="" collection="orbitSlides" template=""}
{% for i in orbitSlides.items -%}
<li class="{% if forloop.first == "true" -%}is-active {% endif -%}orbit-slide">
<img class="orbit-image" src="{{i.['Image Field']}}" alt="{{i.['Alt Text Field']}}">
<figcaption class="orbit-caption">{{i.['My Caption']}}</figcaption>
</li>
{% endfor -%}
</ul>
{module_webapps id="XXXX" filter="all" resultsPerPage="10" hideEmptyMessage="true" rowCount="" collection="orbitBullets" template=""}
{% for b in orbitBullets.items -%}
<button {% if forloop.first == "true" -%}class="is-active"{% endif -%} data-slide="{{forloop.index0}}"><span class="show-for-sr">{{b.['Slide Details']}}</span>{% if forloop.first == "true" -%}<span class="show-for-sr">Current Slide</span>{% endif -%}</button>
{% endfor -%}
</nav>
</div>
As long as the items are sorted the same, I believe this will work.
Hope this helps.
Hi Linda,
Thanks for your quick reply and your effort. I will this out and let you know if it works.
Krgds, Carla
Hi Linda,
Thanks for providing the code. It also helped me to understand liquid mark-up better. Everything works great.
Krgds Carla
