February 2015 my hard drive and mother board failed. Apple replaced the mother board and I paid for a new solid state hard drive.
Since then, my Digital Reader has not functioned.
I now urgently need to download an ebook for work purposes and I'm not able to do so.
Same problem a year ago but I never pursued the problem to a conclusion. Now I must.
WHY CAN'T I AUTHORISE MY COMPUTER WITH A NEW HARD DRIVE?
This is Adobe's solution to solving problems? A forum? Unbelievable.
I can no longer read my ebooks. When trying to authorise my computer I continually get this message:
An Error Has Been Detected
Activation Server error - code E_AUTH_NOT_READY
Digital Editions encounter an error on the activation server.
I've purchased a new ebook today and it won't open.
I get the same message as above when I try to authorise my computer?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
