Help! I always use this feature to capture a shot from some video footage from my DJI Phantom. It saves me time of having to snap lots of still pictures. When I used to use the "capture frame" drop down menu from the video playback bar in the library function, the frame I would capture would appear right next to the video in the line of photos at the bottom of the window. Now it shows up as a stack, and even though I have tried all the options under stacking when I right click on the selected frame, I only get a change in the way the stack icon shows up. I now don't see the captured file anywhere. This has only just recently been a problem so I am assuming an update changed something in my settings, or this is a bug. On a scale of 1-10 of my knowledge of this program, I am between a 2-3. So, if I am missing something simple, please keep that in mind. Thanks!
It may be that you have a filter set that is preventing the capture frame from showing up in the filmstrip at the bottom. Make sure that Library > Enable Filters is unchecked and then try capturing the frame again.
Next, it may be that stacks are collapsed by default. Do Photo > Stacking > Expand All Stacks. Now when you capture a frame, it should appear in a stack at the bottom, but with the stack already expanded.
Finally, if you are currently viewing a collection or smart collection that con
...Copy link to clipboard
Finally, if you are currently viewing a collection or smart collection that contains the video, that is, if the collection is selected as a source in the Collections panel in the left column of Library, then when you capture a frame, it won't show up at all, because LR doesn't automatically add the frame photo to the collection.
I have the same issue, it's not a that the video is in a collection or that Filters is unchecked. When you import it puts your files in a Import "bucket" that acts like a collection. If you right click on any image and select "go to folder in library" you will see the image you captured from video as expected.
Thanks, that's an one more thing to check. When you import, by default the current source is changed to Previous Import in the Catalog panel on the left-hand side. As you observed, with respect to stacking, Previous Import acts like a collection, and stacks are specific to the collection or folder in which the stack is created. Capture Frame creates a stack in the folder containing the video, so you can only see that stack when you set the current source to the folder or All Photographs. (One more wart caused by LR's weird stacking design.)
Problem persists, despite Adobe training Videos showing steps that do not address this problem.
I have made sure Unstack is selected, I don't have filters, The captured frame is till stacked and I am unable to free it as a separate photo. I do not have a collection of the video created.
The only way I could get the captured frame to appear was by Creating a Collection with the video inside the collection, capturing the frame I wanted while I was in the Collection, then going to Library>Grid View. Then and only then did the captured frame appear.
Please continue the discussion here: Lightroom Classic: Stacking / Unstacking Frame Capture from video. | Photoshop Family Customer Commu...
Have you tried following these directions in the new Lightroom Classic CC…they didn’t work on my Mac with the latest operating system and software from Adobe.
Marcia Zeigler
mszig@mac.com
Let's continue in the other thread.
