Index appears "stuck" and cannot scroll
Apr 26, 2016 Apr 26, 2016
I published a project in RoboHelp 2015 to a server for our iPads/iPhones. I have a fairly lengthy index. When viewing, I cannot scroll down the index list to view all topics available. It works only after I do a search within the Index. After searching, I am able to go back to the index tab and scroll down the list. Any suggestions?
405
I should also mention that I generated the Responsive layout.
Adobe Employee ,
Hi
Thanks for reporting the issue.
Have you tried this after applying the update 3 and using fresh new layout from that?
If you still get the issue, could you please share us (amitjha@adobe.com) the published output link or project?
Amit Jha
@amit Projects will not get past your filters, I have tried.
@lmlederer Use something like wetransfer.com
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
As an afterthought, does this happen with all browsers?
@petergrainge
Apr 27, 2016 Apr 27, 2016
The project is also published online through our SharePoint and the Index works with no issue.
Apr 28, 2016 Apr 28, 2016
So in your original post the issue was only when you were viewing locally, correct?
If so, please try locally with more than one browser to see which, if any work. Then repeat viewing from Sharepoint to see if the results change.
Another feature in an earlier version worked when published but not when viewed locally, hence exploring the same line.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
