I have an older Nook. I bought a new PC 5 months ago. It uses Windows 10. I cannot successfully transfer books I've downloaded from my public library to my Nook. There is a transfer taking place but when I access the book in Documents it shows the author as "Unknown Author". The title is shown correctly. When I try to open the book I receive an error message saying the book is unavailable/has been returned. The book has not been returned. It's still in ADE where I can open it and read it. I have uninstalled and reinstalled ADE. I have unauthorized and re-authorized my Nook. Neither step solved this problem. I know the Nook can still accept books correctly because I used my old computer to do this a few days ago.
How do I make my new computer transfer to my Nook correctly?
Which version of Digital Editoin you are used?
ADE 4.5.
Has you check if its work with a older version:
After trying nearly everything else suggested in this and other forums, reverting to ADE version 3.0 did the trick. I had to manually remove my computer's authorization, of course - instructions for that can be found elsewhere in the Adobe forums, or here:
Adobe Digital Edition Woe - "Error! Check Activation" - How I Fixed It - learnbyblogging.com
After following those instructions, then opening ADE and re-authorizing my system, files transferred as expected and I was able to access them on my device again. It seems ADE 4.5 wasn't interfacing well with my first-gen Nook. Very happy to be back up and running with Overdrive titles from my local library.
Thanks.
