Can I use video I took on my Android to incorporate it into my Captivate 8 files? I am pretty sure the answer is yes. I would have to make a path go to the correctly directory where the video is saved, correct? Until then I can have it read off my hard drive?
Even if the format of the video is already MP4, I would suggest you re-encode it with the Adobe Media Encoder app that comes with Captivate because this seems to improve the compatibility of videos with Captivate.
For your eventual end users, your video will need to be delivered from a web server. Whether you will get it to run from your local hard drive will depend on a number of factors. You may find that it will not work due to some browser security issue.
Thanks RodWard. I did find the Adobe media Encoder app that came with the Adobe Cloud. So this app looks basically like a converter tool.
I see I have two versions of the Adobe Media Encoder. One is labeled Adobe Media Encoder CS6 and one is Adobe Media Encoder CC 2015. My guess is one came with Captivate and one came with the Adobe Cloud. I am guessing the Adobe Media Encoder CC 2015 is the latest edition so I will use that version. Correct?
That's what I would do. CC 2015 is the latest.
CS6 comes with Captivate because the last version of AME (CC2015) has no longer flv-format on board, which is still used in Captivate for SWF output.
Thank you!
