RoboHelp 7 - Most Images Missing in Word 2003 Output
Guest
May 27, 2008 May 27, 2008
Does anyone know why my images would stop being displayed 100 pages into a 500-page Word 2003 document? Instead of images (after this point), all I see are tiny green squares. This is after waiting for images to load and formatting the document.
678
Possibly not enough RAM. Instead of using the embed option, use the Link to Images option. Then see Print Issues on my site to convert back to Embedded images in Word.
Guest
Hi Peter,
I came across this fix, but when I selected the link to document option, RH7 froze during the "Generating Printed Documentation" process. I can't get it to cancel now. Strange.
1. Create the document in RoboHelp and choose the "Link to Document" check box.
2. In Word click Edit | Links.
3. In the dialog select all the files.
4. Tick the "Save pictures in Document" check box.
5. Click OK.
This problem is fixed in Adobe RH7 with update 7.01.001 applied.
You mean you cannot close RH or you cannot change the option?
There was a bug that caused a similar problem. This can also occur if you don't have enough RAM.
I have seen the solution for the bug work where RAM was the issue. It may be that when the bug was found, RAM was the cause.
Guest
That's right. I couldn't close the application, so I had to force a close in Task Manager. I noticed (after ending the process) that new files where added to project root folder (*.trb, *.trf, *.trglol, *.trdxl, *.trk, *.trl, *.trs, *.trt, *.trtod, *.trv). Any idea what these are?
May 28, 2008 May 28, 2008
I've not seen or heard of those, and with the couple I tried, neither has Google!
Have you tried opening one in Notepad for clues?
Your first post refers to green squares, usually they are red.
Try creating a new layout?
Also try creating a printed output from one of the supplied projects.
Advisor ,
Have we determined whether this poster is working on a network (which is a very scary thing)?
Good luck,
Leon
RoboHelp Documentation
Download Adobe RoboHelp
