Hi Melissa,
It sounds like you are not understanding the use of
Captivate. Or just as likely, I do not understand your description
of your use. Can you share the project file with me? If so,
click
this link to upload your CP file
. Do NOT send me your published output file ... I need to see
the *.CP (source) file in order to understand you.
What is at issue is what you mean by inserting your Captivate
content into a "course". Normally, Captivate IS the course, so if
the problem is inserting Captivate output files into some other
program, don't bother with the file ... you need to contact the
support folks for that other software application.
Hope this makes sense to you. If you send me your file, you
will find a "Description" blank on the Uploader ... be sure to fill
that out completely, describing your problem and objective, before
uploading the CP file to me. Also fill in the email address blank
so I can get back to you.
~thanks
Larry
