26 Replies Latest reply on Dec 26, 2017 6:45 PM by byroncortezh
    Bezier handles in graph editor
    pjbarbour_rotor Level 1
      Scoured Google, scoured Adobe Forums. Can't find how to get the bezier handles to show up in the graph editor inside of Adobe AE CC 2015.2. I have two keyframes for position set. No matter what I do, I cannot get the beziers handles to show up so I can customize my movements. Any ideas?
        • 1. Re: Bezier handles in graph editor
          Szalam Adobe Community Professional & MVP
          Try applying easy ease to your keyframes first and then go into the graph editor.
          • 2. Re: Bezier handles in graph editor
            Nope, doesn't work. I have two keyframes set on the position of a camera. Adobe bug perhaps? It wouldn't surprise me. CC2015.0 was (by far) the worst ever release by Adobe. 2015.2 has worked fine, but now this.
            • 3. Re: Bezier handles in graph editor
              Could you share a screenshot? I've not had this issue.
              Try switching what type of graph you're looking at (speed vs. value).
              • 4. Re: Bezier handles in graph editor
                I don't know how to change the graph type. Screenshot attached. No bezier handles when I click on the keyframes in the graph editor. Untitled-1.jpg
                • 5. Re: Bezier handles in graph editor
                  I think I may have figured it out. The value graph doesn't allow for there to be Beziers. But I found the speed graph (buried in the settings), and I can see bezier handles there, which is what I wanted all along. All the tutorials I found didn't distinguish between value and speed. That probably needs to be made a little more obvious how to switch between value and speed graph in future releases.
                  • 6. Re: Bezier handles in graph editor
                    Rick Gerard Adobe Community Professional & MVP
                    The graph editor is a powerful tool but it isn't intuitive. To learn how to use it type Graph Editor in the Search Help field at the top right corner of AE and check out the community resources. You'll find some great info. NOT all properties look or are edited in the same way. Not all handles will bend. Some properties are not really editable in the graph editor because their parameters don't make any sense and are not controllable in that way.
                    One more thing, when you're trying to edit speed it's really difficult to visualize exactly what's going to happen by just looking at the graph editor. The Value graphs are easier to understand for things like position or rotation. It just takes some time to get used to. The best way to start learning the graph editor is to just add a small solid to a new comp and start animating position. Use the Keyframe assistant to add easing and watch what happens to the graphs to see what the curves are supposed to look like before you start tweaking them. Try separating values for position. Play around and try and get some very simple motion to do what you want it to do and then start expanding to other effects. Position, scale and rotation are just about the only thing I ever use the graph editor for.
                    I will often use keyframe interpolation to set my easing percentages instead of trying to drag things around in the Graph Editor. I can quickly see if I'm making the right decision. You'll find it by right clicking on a keyframe picking the options.
                    1 person found this helpful
                    • 7. Re: Bezier handles in graph editor
                      adamneer Level 2
                      I'm the exact opposite - I think the graph editor makes it easy to visualize speed changes (after all, that's the whole point) and the Keyframe Velocity makes absolutely no sense to me.  I only pull up that dialog when I need to lock the incoming and outgoing velocities.  I keep the graph editor in Time view mostly.  I find it to be the quickest way to set my easing curves, rather than having to right click and select easy ease (which is pointless anyway since I never use the default ease curve).  Set my keys, highlight them, click graph button, click easy ease button on bottom right, pull handles inward on both keys, done.  The value graph is useful to me only when adjusting camera tracker positions, since it gives the best view of improper spikes in location.  What I don't like is that the value graph is really only useful when your dimensions are separate, but once you separate them, it's hard to keep speed ramps even since you can't lock handles/bezier curves.  Using the script Ease Copy has cut down immensely on my need to edit graphs though, since I usually keep my speed curves consistent throughout a video, so I only have to set them a few times and then can copy and paste them to later keys.
                      • 8. Re: Bezier handles in graph editor
                        Jesse Kerman Level 1
                        You may have discovered this already, but if you want bezier handles for position keyframes, but want to stay in the value graph editor instead of using the speed graph, all you have to do is separate the dimensions and you'll get the handles.
                        • 9. Re: Bezier handles in graph editor
                          hetfdex Level 1
                          THANKS JESSE!
                          • 10. Re: Bezier handles in graph editor
                            Gingerfinch_nz Level 1
                            I have been using the graph editor for more than 13 years ... how come I have the same problem!?? I cannot find the handles...!!!!
                            • 11. Re: Bezier handles in graph editor
                              The Graph Editor was introduced in AE 7.0 released January 2006. That's 10 years but I'll give you the benefit of the doubt. Some properties do not have bezier handles. Others do. What property are you trying to adjust with the Graph Editor? If we had a few workflow details may be we could help.
                              • 12. Re: Bezier handles in graph editor
                                Fair enough... maybe it was introduced later... all I was trying to say is: I know what I'm doing.
                                I have been trying to edit the bezier handles of the position keyframes ... so nothing fancy (see screenshot attached)
                                It worked on this project but all of a sudden it looked like this... I cannot find the handles in any of the settings.2016-07-06_1154.png
                                • 13. Re: Bezier handles in graph editor
                                  Hi Gingerfinch -- you're editing in speed graph mode with "Show Reference Graph" turned on (which is why your two position curves have no keyframes visible). You can fix it by unchecking the Show Reference Graph option in the graph menu (the icon right next to the eyeball in the lower left corner of the graph editor) and going back to value graph mode in the same menu.
                                  • 14. Re: Bezier handles in graph editor
                                    Thanks Jesse!! I'm so annoyed with AE by now that I lost my patience...
                                    • 15. Re: Bezier handles in graph editor
                                      Roei Tzoref Adobe Community Professional
                                      you could still use the reference graph and manipulate handles at the same time: the idea is that the un-active graph is with no handles or pivot squares (don't know the exact technical term for this squares on each end), while the active one is. meaning that if you set a check-mark on "Edit Value Graph" and check also "Show Reference Graph", your value graph handles and pivot squares will be visible (if it's position value, you would have to separate dimensions to see the handles). in the screenshot you provided you are in "Edit Speed Graph" checked ON,which is the default for position and that's why there are no pivot squares on X and Y in the value when you select position. handles will appear as soon as you click on the pivot squares (in the speed graph). you also did not separate dimensions so if you do want to manipulate the value graph you would need to do that.
                                      • 16. Re: Bezier handles in graph editor
                                        Gutterfish Adobe Community Professional
                                        It's frustrating when you lose your patience.  How long did you have them for?  13 years?
                                        • 17. Re: Bezier handles in graph editor
                                          Your graph is not set to auto scale and there are no keyframes visible. I think that's the problem because I can reproduce it.
                                          The the graph editor stops responding as you expect start clicking on the settings at the bottom. Notice the blue (selected) 5th icon from the left...
                                          • 18. Re: Bezier handles in graph editor
                                            Thanks guys. I think I messed up the setting in the graph editor because I switched everything off and on to see if this will bring back the keyframes. Honestly, ever since the interface changed from orange highlights to blue ones (Why!!??) every new update brought new frustration. Before cloud was there you just waited a year or so until you got the new version (so most bugs were fixed) but with the "download new version" link on hand of course you are tempted to update soon after the release.
                                            I needed to use Duik... otherwise I would still be using AE2014 (it is not compatible with the latest vers of Duik)
                                            http://duduf.net/index.php/products/after-effects/duik/
                                            • 19. Re: Bezier handles in graph editor
                                              someone trying to be funny here.. ho,ho...
                                              • 20. Re: Bezier handles in graph editor
                                                jodiLK Level 1
                                                Create a path, then click on any key frame from the path. Right click on it to reveal the sub menu then click on Mask & Shape Path and then uncheck RotoBezier... works! : )
                                                • 21. Re: Bezier handles in graph editor
                                                  Jodilk it appears you Are referring to bezier handles of the path itself in the composition window whereas the thread is about handles in the graph editor - this is something else.
                                                  • 22. Re: Bezier handles in graph editor
                                                    schtals_LV Level 1
                                                    Graph editor is the MOST HATED interface on otherwise the most powerful design application to date, all in my subjective opinion. But seriously, Adobe - LISTEN TO YOUR USERS: add bezier handles to the value graph. That is all we want!
                                                    • 23. Re: Bezier handles in graph editor
                                                      You have bezier handles on anything other than merged coordinates (like position). you can separate dimensions on transform position to get access to those. If you mean you want more flexibility with separate dimensions to get more bezier control in the hraph, please ask for it in the wishform page.
                                                      • 24. Re: Bezier handles in graph editor
                                                        everharta Level 1
                                                        Simple Animation Tutorial - After Effects - YouTube
                                                        At 21:21 he talks about not getting the bezier handles in the graph editor. You have to select the points and click "Separate dimensions". Then you can click on the points and click "Convert selected keyframes to auto bezier" .
                                                        • 25. Re: Bezier handles in graph editor
                                                          Roland Kahlenberg Level 3
                                                          Everharta is correct — Position Keyframes in the Graph Editor will not have Bezier Handles for its Value Graph unless Separate Dimensions is turned on.
                                                          • 26. Re: Bezier handles in graph editor
                                                            byroncortezh Adobe Community Professional
                                                            The only way to see de handles in the Value Graph is separating dimensions. In other case you have to select Speed Graph, not Value Graph.
