3 Replies Latest reply on May 6, 2016 12:02 AM by Nanaky
    Error getting license
    CathyM121
      When I try to download a library book I get "Error Getting License. License Server Communication Problem: E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
      I have just re installed ADE to newest edition.
        • 1. Re: Error getting license
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
          • 2. Re: Error getting license
            mlf0033 Level 1
            HI Nansky,
            It did work , but not at first.
            At first the error message changed from having a problem with my Id and
            /or password to having a problem with multiple accounts, mobile etc..
            I finally opened  my adobe account info.  I saw there was an alternative
            email entered that was only supposed to help if I had to recover a lost
            password. I removed the alternative email.
            Only then was I able to register my adobe id.
            Manny
            • 3. Re: Error getting license
              Nanaky Level 5
              Fine that it now work.
