https://bugbase.adobe.com/index.cfm?event=bug&id=4099489
Hello Adobe team,
it seems, that only the last beta versions are affected and not the final versions.
It will crash on some flash based video websites with protected mode on/off.
Some example websites:
(select one video and click on the fullscreen button)
Flash Player 20.0.0.274 beta
32-bit = Crash Reports in F_1799236063__________________________________________________
64-bit = Crash Reports in F_828422936____________________________________________________
On Dailymotion.com the video's are crashing directly while loading the page.
https://crash-stats.mozilla.com/report/index/864486ec-4b5f-4cc4-90e9-0ab162160108
Hi Jeromie,
I have retested it with Flash Player 22.0.0.137 & .144 and Firefox 47 Beta & Nightly 49 and it is working now.
dom.ipc.plugins.asyncdrawing.enabled was set to true for the tests.
So I would say that we can close this topic as fixed with Flash Player 22.
MrX1980
Flash Player 20.0.0.279 is working again. Thanks
Update: I forgot to re-enable the Flash Player hardware acceleration.
https://crash-stats.mozilla.com/report/index/7dc36cc1-6f19-42d5-87b7-012072160109
https://crash-stats.mozilla.com/report/index/b226f1d6-78da-4bda-96a4-6f7dc2160109
If I use "adplus.exe -crash -pmn plugin-container.exe -o D:\debug\dumps" then I see something like:
(1174.f4c): C++ EH exception - code e06d7363 (first chance)
(1174.11f8): Access violation - code c0000005 (first chance)
(1174.11f8): Unknown exception - code c000041d (!!! second chance !!!)
[JavaScript Error: "SecurityError: The operation is insecure." ...]
###!!! [Parent][MessageChannel::Call] Error: Channel error: cannot send/recv
###!!! [Parent][MessageChannel] Error: (msgtype=0xAA0020,name=PPluginInstance::Msg_NPP_DidComposite) Channel error: cannot send/recv
Thanks for reporting the issue. We are looking into it.
Again, v20.0.0.286 final is working and v20.0.0.294 beta is crashing.
So something is different between the final and beta builds.
Different compiling options ?
Any chance this is an Intel 4400 GPU?
Hi Jeromie, in the crash reports I see all main vendors (Intel, nVidia and AMD/ATI), so it is not a graphic card/driver problem.
I use:
- nVidia GeForce GTX 650ti / v361.60
- Intel HD 3000 (i5-2410M) / v9.17.10.4229
- ATI Radeon HD 4670 AGP
https://crash-stats.mozilla.com/report/index/1ea52f4f-6309-4b53-ab04-84fc82160126
https://crash-stats.mozilla.com/report/index/157e91e9-c56e-419f-ad35-8e2b52160125
Okay, thanks. I'll dig into this today. I didn't have time to look at it yesterday, but I've been seeing some nasty crashes moving in and out of fullscreen specific to the latest Intel 4000 HD drivers. I was hoping it was the same issue.
This issue is known to us. We are looking into it.
This issue remain with the latest 21. ver on anybrowser I have a Nvidia Gforce card ( laptop )
win 10 x64 pro in case is necesary
thanks for your help
Yeah, this issue is open and assigned. You can subscribe to the bug (see the first post in this thread) for updates.
Thank you will do
Raps
This issue will be fixed in latest FP beta version which will be live today.
Hi, thanks for the update, but sadly it is still crashing with v21.0.0.136
Yes definitely still present
you dont even need to go full screen
just do a right click on the video box and click on the first icon on the menu
will crash instantly
Regards
This is not reproducible on my machine :
Firefox 47.0a1/21.0.0.136/Intel HD 4400 graphic card/win 7 64 bit
But I could see a crash on win 7 /Firefox nightly with AMD Radeon graphic card machines.
Please try below steps. I believe it will resolve the issue:
1) Type "about:config" in the address bar of Firefox Nightly and search for dom.ipc.plugins.asyncdrawing.enabled and set it as false
2) Now play the videos.
Hi, I know that is better with dom.ipc.plugins.asyncdrawing.enabled;false, but the question is, why it is crashing only with your beta builds and not with the final builds?
dailymotion.com
fullscreen button
We're collaborating with Mozilla on the feature. That feature requires code to be present in both products in order to be active. Our next beta build should resolve this.
Hi, it is still crashing with FP 21.0.0.157 and Firefox 45.0b6 64bit & 47.0a1 64bit (dom.ipc.plugins.asyncdrawing.enabled;true)
I'm no longer seeing traffic on these signatures. Just wanted to confirm that this was resolved before closing it out.
Hi Jeromie,
MrX1980
Great, thanks a lot for the confirmation.
