Sreekanth, welcome to the forums.
I was working on responding when Column replied, so here's
some detail.
Here is what we do in a Java application:
1. I have a RoboHelp project for each language. In your case,
this would be a project for English and a project for French. (For
an explanation why I do it this way, see
this
page.)
Keep all map IDs the same between the two projects.
2. Put your output files in two separate directories, such as
"en" and "fr."
3. The developers put the "en" and "fr" values in a database
table.
4. The developers code the "Help" link so that when clicked,
it detects which language is being viewed, and the Java takes the
appropriate value ("en" or "fr") and inserts it in the appropriate
place in the path to the help start page within the CSH help call.
For example, if your help systems sit in these directories:
.../help/en/startpage.htm
.../help/fr/startpage.htm
Your help call for an application page could look like this:
RH_ShowHelp(0, ".../help/%lang%/startpage.htm",
HH_HELP_CONTEXT, 6)
...where 6 is the map ID for the particular page where you
are calling help, and %lang% represents whatever code the
developers put in there to represent that it's variable.
When the help is called, the Java inserts "en" or "fr" in the
variable in the path so that it opens the help from the correct
directory.
If you're not doing help for a Java app, maybe there's
something in this description that is adaptable to your situation.
(Another option is to have two separate help calls, one with "en"
in the path and one with "fr" in the path, and the application is
coded to use one or the other depending on the language being
viewed.) Bottom line is you'll want some developer help with this.
--Ben
