downloaded books from overdrive to my PC (windows 7). When opened in overdrive the page #'s appear on the right hand side of the page, sometimes over the last few letters of a sentence. Can this be fixed to have #'s at the bottom of the page ?
Do you have the probem in which Progam? Do used which os?
I am using windows 7 and an older version of ADE. Since my initial post I located and installed ADE 4.5.1 which has create a new challenge. When I try to download books from a library I get the message: ā Check Activation ā with no error code attached. The Adobe chat line suggested I de authorize Digital additions. However when I attempt this I am asked for a email address and password. (the only password I have is to access my Adobe account). When I use this password the system says it is incorrect. I tried changing to a new password however this was met with the same response. Any suggestions as to how one should proceed
grant
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Good Evening
Thanks for the advice . this resolved the problem
Grant
You are welcome.
