Is this the same issue as you posted in
OK
to use RH with Subversion ? You might want to add a comment to
divert people to this post instead, so people can find the
discussion.
I don't have Subversion myself, but I suspect the process
would be similar. Hopefully someone with Subversion will correct
anything that isn't.
First, I have had a couple of projects which haven't upgraded
all files correctly when moving from X5 to RH6. It seemed to help
when I checked out the project manually before opening it in the
newer version of Robohelp.
As you say you are restoring an earlier version, possibly my
original though about your issue wasn't correct. In this case, the
following comments are our solutions to patching older versions of
our help.
I've found that if you need to go to an old version of RH, or
someone else has worked on the project since you last did, it's
best to delete the CPD file, as it seems to store information about
files, so if any have been added or removed, the changes may not
show up due to this "cache".
Additionally, when you start to edit a topic robohelp will
get the last version checked in. So if you want to work on an old
version, it will automatically "get" the newer version when it
checks out the file.
The process we use is:
1. Manually check out the entire project using SourceSafe.
(this ensures RH won't try to checkout and get the latest file.)
2. Show History and Get the specific version we want to work
on. (In VSS, we use the Label function for each version, as it
seems to do a better job of getting all the correct files than
working on dates.)
3. Delete the CPD file.
4. Open the project in RH.
If you then need to go back to the "newer" version, you have
to do the same again, just getting the applicable version in step
2.
Possibly there is an easier or more efficient method, but
this works for us.
Hope this helps,
Amber
