W_ADEPT_CORE_WRONG_DEVICE
Apr 22, 2016 Apr 22, 2016
When I try to download an Ebook on a second computer, I receive the error message "W_ADEPT_CORE_WRONG_DEVICE".  I did not have any issues with this on my first computer.  I have deauthorized the first computer and gone through the steps to remove the Adept Key through the Registry Editor, and still no luck.  I create an account and use my Adobe ID so that I could view the purchase on multiple devices.
4.6K
Apr 24, 2016 Apr 24, 2016
Has you authorize the secound Device with the same Adobe ID as the first?
Apr 25, 2016 Apr 25, 2016
Yes, I tried with the same Adobe ID.
Has you check if you can copy the eBook to a secound device? (Right Click in Digital Edition > Media-Info).
Apr 26, 2016 Apr 26, 2016
Unfortunatly, now I am getting an error message under Item Info > Permissions that "License Key is Damaged".  I attempted to deauthorize my computer to re-authorize it (using Ctrl+shift+D), but when I try, I receive an error message "Unable to Erase Authorization.  Please try again after some time."  I restarted my workstation, but receive the same error.
"License Key is Damaged" is a error with the file itself. Remove the file and download again with a other Internet Browser.
Where is the file located to remove?
Has you try to remove it direkly in Digital Edition?
Apr 27, 2016 Apr 27, 2016
The only option I see is to remove it from the Library; this does not erase the actual file.
Its this a file with the cloud symbole?
No, there are no cloud symbols.
Apr 28, 2016 Apr 28, 2016
Then you should it mark at remove. Get you a error message or its not work?
May 02, 2016 May 02, 2016
I cannot remove the file from ADE.  I have to locate the file in it's original location.  Please provide me with the correct file path.
Which OS do are used exactly?
May 03, 2016 May 03, 2016
Windows 7
Then you should have a My Digital Edition Folder under your Documents.
May 04, 2016 May 04, 2016
Ok, I was able to erase the files. Now, I am receiving a different error message when trying to open a document: "E_AUTH_BAD_DEVICE_KEY_OR_PKCS12"
May 06, 2016 May 06, 2016
Windows:
    Close all applications.
    Choose Start > Run.
    In the Open text box, type regedit and then press Enter. The Registry Editor opens.
    In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
    Select the Adept key.
    Choose File > Export.
    In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
    Right-click the Adept key and choose Delete.
    In the Confirm Key Delete dialog, click OK.
    Close the Registry Editor.
    Open Adobe Digital Editions and reauthorize.
Thank you!!  I am now able to view the documents on my computer again.  However, I still have the original issue and error message when I try to open the book on a second computer.
May 08, 2016 May 08, 2016
You try the same steps on the secound Computer?
May 09, 2016 May 09, 2016
Yes
And you get the same error o.O sure that you have full permissions with your user.
May 10, 2016 May 10, 2016
Yes, I have no reason to believe otherwise.
Has you check if you get the same error with a other user of your device?
When another user tries, they receive the same "W_ADEPT_CORE_WRONG_DEVICE" error, even though I was able to authenticate with my same Adobe User ID.
