5 Replies Latest reply on May 16, 2016 2:28 PM by Paul Michelle
    trapcode particle to motion path
    study.12391374 Level 1
      Greetings,
      Hopefully this can be answered without me giving too much info.
      I tried setting setting up particular to follow a motion path via a YT video and I am getting strange results.
      I'm using AE 13.2.0.49  (2014)
      I create the solid\particle layer at default settings.
      I create a light named Motion Path
      I create a default camera (not sure if this is necessary but...)
      I set some animation on the light
      On particle effect i go to physics>air and set motion path to 1
      The problem is that it seems the ""death" point is following the path rather than the birth point.
        • 1. Re: trapcode particle to motion path
          Mylenium Most Valuable Participant
          I see nothing wrong in your video. The particles are emitted every step of the way and retain their position according to their emission properties. You simply need to change those options like velocity and motion inheritance or enable the aux particles if you want a different look. It might be a good idea to spend some time learning the plug-in first by playing around rather than following potentialyl "bad" tutorials that leave a lot of things out because they assume you already know this stuff...
          Mylenium
          • 2. Re: trapcode particle to motion path
            Paul Michelle Adobe Community Professional
            Hi Myl,
            Sorry I posted my question on the wrong account.
            So how would I get the light to leave a trail of particle?
            Like if a smoke bomb was thrown and left a smoke trail?
            Just animate the emitter?
            My issue with that is that it does not create an editable bezier path.
            At least not how I'm doing it so maybe if there's a way to do that you can tell me.
            Just for the record in the tutorial (I can link it if you want)
            when the dude sets it up the particles emit FROM the light and leaves a trail of particles.
            When I set it up exactly the same the particles emit FROM the emitter, not the light.
            • 3. Re: trapcode particle to motion path
              Szalam Adobe Community Professional & MVP
              If you want a smoke bomb thrown kind of look, you don't want a motion path. A motion path means particles will flow along a path. You want to animate the emitter.
              If you want an easily-edited Bezier path, you can either choose to use a light as an emitter (by setting the emitter type to "light" - see the help file for more info) or tie your emitter to a null object using a couple of expressions.
              • 4. Re: trapcode particle to motion path
                As per Szalam's words: Particular can use lights as emitters or you animate the position properties in the effect directly. Simply set the emitter options accordingly and then set the particle type to cloudlet. the only caveat with lights is that you lose some of the options for coloring, since those parameters are supposed to be controlled by the light color.
                Mylenium
                • 5. Re: trapcode particle to motion path
                  Thank you both,
                  Paul
