It doesn't happen all the time, but on random ebooks I try to return. I am using ADE 4.5 on Windows 7 Pro 64-bit. After I re-open IDE, when I try to return the book again, it claims a E_BAD_LOAD_ID, and I can only delete it from my library instead. The following are two error messages that I get from the Windows before it crashes. Seems like it's identical.
Problem signature:
Problem Event Name: APPCRASH
Application Name: DigitalEditions.exe
Application Version: 4.5.1.0
Application Timestamp: 56728e87
Fault Module Name: StackHash_0a9e
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 00511514
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Problem signature:
Exception Offset: 006e1374
Locale ID: 1033
Has you check if the Library has problem with the eBook server?
