2
CS6 Camera Tracker Points not Showing
Sep 13, 2012 Sep 13, 2012
Hello, I am unable to get the points to show with the camera tracker. The tracking points show only when I check render track points but I am unable to move my mouse pointer over them to interact and assign anything to them. I have everything on the highest quality settings.
I attached a screenshot in case someone can see any setting I missed clicking on.
I have an iMac with:
Processor  2.4 GHz Intel Core 2 Duo
Memory  4 GB 667 MHz DDR2 SDRAM
Graphics  ATI Radeon HD 2600 Pro 256 MB
Software  Mac OS X Lion 10.7.4 (11E53)
Thank you,
Scott
Error or problem
40.0K
New Here , May 09, 2014 May 09, 2014
I think I found the problem. I had it before, and it may be an easy one.
View>"Show Layer Controls
It is easy to hide them by mistake, and it hides your control points as well.
I hope this helps!
Look at this....
...and this...
...and this, too....
...and as a reference, keep this handy.
Most AE features aren't very intuitive, and you need to get trained up.
Thank you Dave, I know how to use the camera tracker. The tracking points do not show up. I read in another thread to turn off open gl acceleration in my comp window to fix it but I do not see any settings in After XF to turn that off.
Thank you,
Scott
I just took a second look at your computer specs, and you only have 4 gigs.  That's nothing in AE terms.  You need to trick that thing out with memory.  I suspect you're tracking a clip that's longer than ever attemped before, and you're running out of RAM as AE analyzes the clip, leaving no track. points.
For now, turn off multiprocessing if it's on -- there's no way you can use it -- and you shouldn't have to worry about AE using Open GL; it's not an option any more.  Additionally, you should make sure your Radeon driver is fully updated; it too is a cause of AE not performing as advertised.
My Graphics Card is updated but still these points dont show. The video clip is not long at all- 37 seconds and the project does not bog down the machine at all with 4GB of Ram. I have had some massive projects loaded in here before with like 25 to 30 layers and it would work quite well. I love this camera tracker if this iMac would allow it to work. Will Adobe be looking into this problem anytime soon?
Thank you,
Scott
Advocate ,
Scott, I had the same issue yesterday . I have had lots of experience using (beta testing) the AE Tracker as well as Syntheyes and The Foundry Tracker.  I tracked a clip and NO tracking points or targets were visible. I deleted the clip and the comp and created a new comp from the clip. It worked that time
I have an HP Z820 with 64 GB of ram so I dont think ram is my issue. Im also up to date with the Nvidia drivers for my GTX 570 card. I know Nvidia has been the source of lots of different CS6 issues recently so my money is on that.
Sep 14, 2012 Sep 14, 2012
Thank you all! I finally got it working. Deleting and starting over fixed it! I have to assume there will be Bugs with new features.
Thanks again!
Scott
Advocate ,
You are welcome. Its a shame its buggy, but Im glad deleting the clip and redoing the track worked.
Sep 03, 2020 Sep 03, 2020
Yup, this solved my issue
Thank you
Turn off all graphics accelleration in your preferences. Set comp window to Adaptive Resolution. If you click render points and see them, then you uncheck render points and they go away there's some other conflict.
Change your comp view to Active Camera.
Solved????
Thanks Rick, I set to Active camera and points still not showing.
Dec 03, 2019 Dec 03, 2019
idiot
I hope this helps!
Jun 16, 2015 Jun 16, 2015
Thats it!!!
Participant ,
Oct 25, 2015 Oct 25, 2015
Mann ...thanks for this forum,, problem solved. Show layer controls is the key! thank you
Nov 19, 2015 Nov 19, 2015
Sweetness. Thank you. This was driving me crazy.
Jul 10, 2021 Jul 10, 2021
2021 and I ran into this issue... and this forum (and Felipe Ruiz Mendoza) provided the answer I needed.
Thank you!
Aug 05, 2021 Aug 05, 2021
Perfect, Thanks Felipe
May 18, 2016 May 18, 2016
few years late but that show layers control just saved me a stress tumour, couldn't find the solution anywhere else! many thanks
Dec 24, 2017 Dec 24, 2017
Quite late to this, but the problem could also bee too much change in the video. I tried tracking a video with a lot of change in 40 frames and saw no points, but when i cut an 8-frame clip from the video and tracked, the points showed up
Feb 11, 2018 Feb 11, 2018
You are a LIFE SAVER.
May 26, 2020 May 26, 2020
You're a legend, Felipe!
Engaged ,
Jun 11, 2020 Jun 11, 2020
It also seems to happen, when the tracker is unable to resolve parts in the beginning of the sequence. In that case, go to where the warning overlay starts to disappear and clip everything before. Then place the footage again, track, and splice the part you cut off back in.
Jul 03, 2020 Jul 03, 2020
It dosent show for me anyway. I have "active camera" on and "show layers control" selected. Still dont get any tracking points
