message "erreur lors de l'obtention de la licence, problème de communication avec le serveur de licences
E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
comment procéder pour rétablir le lien?
marianne5451042
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
merci,:-)
je suis absente pour 10 jours, je ferai un essai à mon retour
Marianne
Le 19/05/2016 08:35, Nanaky a écrit :
Téléchargement impossible d'un ebook
created by Nanaky <https://forums.adobe.com/people/Nanaky> in /Adobe
Digital Editions/ - View the full discussion
<https://forums.adobe.com/message/8759203#8759203>
Good Luck.
