Coldfusion v2016 using SQL server query using order by right causes error.
May 19, 2016 May 19, 2016
Have query that worked until v2016.  Using order by right(LogNumber,3) DESC get error:
Macromedia][SQLServer JDBC Driver][SQLServer]Incorrect syntax near the keyword 'right'
query:
  SELECT LogNumber
  FROM tblMain
  WHERE (Program = 'Apple')
  ORDER BY right(LogNumber,3) DESC
492
Guide ,
Have you applied Update 1 yet?  If so, was this working before the update?
I wonder if it is somehow related to this similar CF11 Update 8 bug: Bug#4153580 - Coldfusion 11 update 8 breaks left and right sql sever functions
I had already installed the Update1 so I uninstalled it and it still does not work.  I looked at the bug#4153580 and that appears to me my problem.  I have determined that if you have a right in the query it works, it's only if you have it in the order by that it doesn't work.
Can you add another column to your select and order by on that?
  SELECT LogNumber, right(LogNumber,3) as rlog
  FROM tblMain
  ORDER BY rlog DESC
HTH,
^_^
That works but should not have to do that.  If you look at the log for bug #4153580, it says they had the same problem after doing update8 on v11.  I just did update8 on another machine running v11 and now I have the problem on that system also.  It appears the problem was introduced in update8 and continued with all v2016.
Documentation
