Hello everyone,
Is there a way to change the default number of rows and columns in the insert tables window in RH 2015? I would like to change them from 3 to 1.
Thank you.
Hi there
Unless Adobe or another user pops in to claim otherwise, I'm going to guess this is hard coded into the application. I performed some registry spelunking and am coming up dry for any setting that might govern this.
My own gut tells me it's likely not possible.
Cheers... Rick
Thanks for getting to me Rick.
Could you not just use the grid and select the table you want afterwards? Hover over the grid to select the number of rows and columns.
See www.grainge.org for RoboHelp and Authoring information
I suppose I could but I find it inefficient as I have to do an extra step to get the same result i.e. an extra right click to get the style for it.
True as it is a personal thing. I find it easier to drag through that grid to immediately get the number of rows and columns that I need in most instances than having to enter the numbers in two fields.
