I've tried everything. I downloaded a book via overdrive. The format is acsm. When I open the book it brings me to ADE and wants me to authorize. I try to sign in with both my adobe password and overdrive password and get the same message.
I've tried the Command, Shift, D to re-authorize but get no pop up window.
I've also gone into the key chain to change access for ADE.
I've discarded Adobe 3 times and re-downloaded new versions.
Nothing works. Anyone have any ideas?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
I had such high hopes. I found the activation.dat file in the library, dragged to the trash. Emptied the trash. Tried again and same message. Any other thoughts? Thanks.
I am having the same issue as you are. I have also gone into keychain access and tried to change the access for ADE but digital editions did not show up on the list of applications. Then I found the file and moved it to the trash. I emptied the trash and tried to open ADE again and it gave me the same error message. I have spent well over 5 hours trying to figure out this issue.
Could you authoirze it or get you the error message when you open it?
