Coldfusion/LCDS/Mysql + Flex
Avatar
Level 1
Hi all !!
I just have a project that use LiveCycle a lot... I begin
from the scratch with integrated ColdFusion LiveCycle,
so i've tried the example in devnet :
http://www.adobe.com/devnet/coldfusion/articles/data_app.html
and everything seems to work with the Coldfusion embedded databases
( I 've just noticed that for some fields when i wanted to upgrade
that fields i get un 'contructor' error, issue that wasn't
resolved, even by his author.
Now my problem is that i use a proper mysql database and when
i launch the same application i get a blank page without anyresult
in the datagrid and no error messages from flex, coldfusion or
mysql...
Is it a known issue or have i to configure Mysql in other way
in Coldfusion ??
Any helps will be appreciated
Francois
Avatar
Level 2
I have tried out exactly this same example; but in my
configuration, the assembler CFCs are not found ... I use an Apache
web server instead of ColdFusion's builtin web server. Have You
made this example running with an EXTERNAL web server ?
Avatar
Level 1
Well i use Coldfusion on IIS... don't have try with apache,
but your problem seems to be the way you call your CFC.. I think
you have to map your CFC path in the admin, but not sure...
regards
Avatar
Former Community Member
Copy the com folder (and all subfolders) to the C:\ColdFusion8\wwwroot folder (or whatever your CF install directory is).  Alternatively I believe you can create a mapping - I have heard others mention it...but I'm not sure how.
