3 Replies Latest reply on May 25, 2016 12:17 AM by sanyamt
    In-design cannot start
    joanne64777900 Level 1
      I am having the problem of in-design right now is that -
      After starting the application, In-design opens the document, but then it becomes "dead" and the program cannot be operated in any way.
      I have tried the In-Design in at least two computers and it appears the same.
      Need a help here!
        • 2. Re: In-design cannot start
          Steve Werner Adobe Community Professional & MVP
          Please tell us the version of InDesign you're using and the operating system you're running so we can help you.
          • 3. Re: In-design cannot start
            sanyamt Adobe Employee
            Can you please share the system configuration? Version of InDesign?
            Please follow the step to clear preference and cache
            • InDesign Preference:
            Windows XP: C:\Documents and Settings\<USER>\Application Data\Adobe\InDesign\<Version #>\<language>\  (Note: Prior to version 6 [CS4] the language folder is not used).
            Windows Vista or Windows 7: C:\Users\<USER>\AppData\Roaming\Adobe\InDesign\<Version #>\<Language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
            Macintosh: Hard Drive/Users/<USER>/Library/Preferences/Adobe InDesign/<Version #>/<Language>
            • InDesign Cache:
            Windows XP: C:\Documents and Settings\<USER>\Local Settings\Application Data\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
            Windows Vista or Windows 7: C:\Users\<USER>\AppData\Local\Adobe\InDesign\<Version #>\<Language>\Caches\  (Note: Prior to version 6 [CS4] the language folder is not used).
            Macintosh: Hard Drive/Users/<USER>/Library/Caches/Adobe InDesign/<Version #>/<Language>/ (Note: Prior to version 6 [CS4] the language folder is not used).
            Sanyam Talwar
            1 person found this helpful
