Error when trying to open from Sharepoint
Guest
Jun 03, 2008 Jun 03, 2008
We have moved our project to SharePoint. From Windows, I navigated to the folder and mapped that drive which is drive X: I tried to open a RoboHelp project from the X: drive and I got the following error:
"The path X:.... is too long and will be deleted from the project." I select OK and then RoboHelp crashes. Anyone know what the problem might be.
Thanks.
Bill
914
RH will only work from a local drive.
Guest
Peter,
Could you please elaborate on this because I'm sure my superiors will be asking my why it only works from a local drive and what does that have to do with SharePoint.
Thanks.
Bill
My understanding is you have moved the project to a network drive as part of sharepoint, correct? Quite simply RH is not designed to work on projects across a network. It is underpinned by an Access database and they do not work well across networks.
I am not understanding why you want the project in Sharepoint anyway.
Guest
We were trying to do version control of the online help since we can't seem to get RoboSource 3.1 working. Having all kinds of problems talking to the database. That was our reasoning.
Thanks for all your help.
Bill
With RoboSource, or any version control, RH checks the required files out and copies them locally while you work. That is OK.
If you can use Sharepoint in that way, OK, but I don't think anyone has reported using Sharepoint with RH, never mind successfully.
Has anyone done this? If so, please speak up.
Guest
Jun 06, 2008 Jun 06, 2008
One of my colleagues has posted WebHelp output files to a SharePoint site in the past, and that shouldn't be any different than moving them to any other server. But it sounds like Bill is talking about placing all the source files in SharePoint, which would then place them on a network server. All the usual caveats about working on source files stored on a network probably apply.
--Ben
Jun 09, 2008 Jun 09, 2008
We did try hosting our output build onto Sharepoint, and found some problems with the URLs from RH being too long for Sharepoint to handle... We stuck to our trusty Unix server in the end!
As for using SP to store the project, we've not tried that, but as the others have said, the Source Control needs to store files locally to work effectively.
RoboHelp Documentation
Download Adobe RoboHelp
