I happened to notice this post and thought, "Yikes, we run
our CHM files on 64-bit systems all the time and we've never
checked whether they're working properly."
So I did a systematic check of the following on a 64-bit
system (Windows 2003 Server). Fortunately, everything worked
exactly as it does on 32-bit versions. Phew!
- Context sensitive help works (pressing F1 in the application).
- All links worked, including popup links.
- All expanding and dropdown hotspots worked.
- Both Index and Contents worked fine. Contents updated
automatically when I move between topics (as is specified in our
project).
- Search functionality worked fine. Search options, too.
- Favorites worked fine. These reappeared even when I closed the
help and reopened it (as they should).
- All of the above also worked when I opened the CHM file from
Windows Explorer (rather than from inside the application).
Eileen
P.S. I should add that the help was compiled using RH7.
