How can I erase authorization so I can reset up adobe digital additions? Right now I am trying and here is the message I get: Unable to Erase Authorization. Please try after some time.
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Mac: Navigate to ~/Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
ADE will be deauthorized now.
Now Authorize ADE again.
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
I am having the same issue as mentioned above - however, do not have an Adept key in the Adept root folder - Only key within the Adept branch is in the device folder (where the key is called "Key")?
