Stuck with Notify / registered script
Jun 14, 2016 Jun 14, 2016
Dear friends,
A Notify function is invoked even before I have explicitly started the script. Well this seems to be purpose of registering a script, but...
The Notify function is executed before the script could initalise and hence I get the message at start of FM (line number according to the code below):
Script Error :
Error Message      : wPalC is undefined
Script, Line#   : E:\_DDDprojects\FM-calc\FM-calc\FM-calc.jsx,  13
(actually this refers to the line 14, because only there wPalC appears.
The Notify routine handles two different dialogues the core of which are set up in functions. Only the window definition is global:
var wPalC  = new Window('palette',"FM-calc : Handle #Calc Markers",undefined);
var wPalDS = new Window('palette',"FM-calc : Manage Document Settings",undefined);
function SetupNotifications () { // Watch for the following notifications =========================
  Notification (Constants.FA_Note_PostActiveDocChange, true);
} // --- end SetupNotifications
function Notify (note, object, sparam, iparam) {  // Handle triggered evens =======================
//$.bp(true);                                     // does not work at all
//alert ("Notify- object:\n" + object);           // this works
  switch (note) {
    case Constants.FA_Note_PostActiveDocChange:   // active document has changed
      goCurrentDoc = object;
      if (wPalC === undefined) {return;}          // registered script is entered before really started
      if (wPalC.active) {
        if (!object.ObjectValid()) {              // after all documents have been closed
          HideButtonsC ();
          return;}
        giNdexOfMarker = RefreshGlobalsC ();      // later: needs to distinguish marker types !!!
        if (giNdexOfMarker !== null) {
          DisplayMarker (goCurrentDoc, goCurrentMarker);
          wPalC.p0.sMarkerContent.text ="";
          gsMarkerText = goCurrentMarker.MarkerText;
          wPalC.p0.sMarkerContent.textselection = gsMarkerText;
          ActivateButtonsC ();
        } else {
          HideButtonsC ();
        CollectVariables (true);                    // fill the global array
        FillUserVars (wPalC.p0.g1.pVar.listVariables); // fill the diaolgue list
      if (wPalDS.active) {
        FillUserVars (wPalDS.p0.tabV.g1.p1.listVariables); // fill the diaolgue list
      break;
} // --- end Notify
So how to test for an undefined something? Do I need ==== ?-)
if (!wPalC.ObjectValid())  {return;}
Does not work either - same error message.
Scripting
461
Enthusiast , Jun 14, 2016 Jun 14, 2016
Hi Klaus,
when you add a notification, you also have to remove the notification.
Register: Notification(Constants.FA_Note_PostMouseCommand,true);
remove : Notification(Constants.FA_Note_PostMouseCommand,false);
But when your script stops before, you have to remove it manually:
Go to the script library (file-> script -> library) to unregister a script.
Otherwise It even stays there even if you restart FrameMaker
Enthusiast ,
Hi Klaus,
Thanks Klaus for this important hint!
Hoever, the removal of the notification should only be done at Close of the FM-session - hence a nested notification...
... and I have found how my test should be coded:
if (typeof  wPalC === "undefined")  {return;}
xxx
