Dear friends
I am more than puzzled about the following
This is the global definition of two arrays:
var gasLocations = []; // filled from template or current document
var gasLocationsPredef= []; // filled in SetUpArraysEtc ()
In function SetUpArraysEtc () they are filled:
// locations for the list in the dialogue
gasLocations1 = ['Above()', 'Below()', 'Left()', 'Right()']; // used in UnknownElement concatenated to gasFunctions
var asLocations2 = ['[COL m]', '[ROW n]', '[CELL n, m]'];
gasLocationsPredef = gasLocations1.concat(asLocations2); // These must not be deleted from the list
gasLocations = gasLocationsPredef;
Later in a dialog function array gasLocations shall be updated. I have set a breakpoint just before at the crucial point:
function ButtonAddLocation () { // ================================================================
// Attention: this regex is different from that in ChecktermElements!
var re_Def = /(\[ROW +\d+\]|\[COL +\d+\]|\[CELL +\d+, +\d+\]|Left *\(\d*\)|Right *\(\d*\)|Above *\(\d*\)|Below *\(\d*\))/;
var item = wPalDS.p0.tabL.g1.p2.g1.sLocation.text;
if (item.search(re_Def)) {
alert (gsDSSyntaxErr);
return;
$.bp(true);
UpdateListLocations (wPalDS.p0.tabL.g1.p1.listLocations, item);
FillItemList (wPalDS.p0.tabL.g1.p1.listLocations, gasLocations);
PutRefPageItems ("Ref-Locations", ""); // update reference page
} // --- end ButtonAddLocationfunction ButtonDelLocation () { // ================================================================
var lstIndex = wPalDS.p0.tabL.g1.p1.listLocations.selection.valueOf();
var locName = gasLocations[lstIndex];
if (IsInArray (gasLocationsPredef, locName)) {
alert ("Predfeined items can not be deleted");
return;
DeleteItemLocations (wPalDS.p0.tabL.g1.p1.listLocations, locName)
} // --- end ButtonDelLocationfunction UpdateListLocations (oList, item) { // ====================================================
// update global array and list in dialogue;
var locArray = gasLocations, j, nItems;
locArray.push (item);
gasLocations = locArray.sort (); // update global array
nItems = gasLocations.length;
oList.removeAll (); // clear the list
for (j = 0; j < nItems; j++) {
oList.add ("item", gasLocations); // add item
} // --- end UpdateListLocationsfunction DeleteItemLocations (oList, item) { // ====================================================
// List is rebuilt from array. Function array.splice not available in ES
var index = IsInArray (gasLocations, item);
var lower = gasLocations.slice (0, index); // lower part
var upper = gasLocations.slice (index+1); // upper part
gasLocations = lower.concat(upper);
FillItemList (oList, gArray);
} // --- end DeleteItemLocationsfunction FillItemList (oList, aSource) { // =====================================================
var j, nItems = aSource.length;
oList.add ("item", aSource); // add item
} // --- end FillItemListfunction IsInArray (array, what) { //==============================================================
// indexOf is not supported in ExtendScript...
var jl;
for (j = 0; j < array.length; j++) {
if (array== what ) { return j;}
return null; // not found in array
} // --- end IsInArray
Now guess what? After UpdateListLocations both arrays have the same content! But gasLocationsPredef should not be updated, as it serves as a reference: Items in the selection list corresponding to items this array must not be deleted from the list. The function ButtonDelLocation always finds the newly inserted item and does not accept the deletion.
Once I read a warning about global variables - but I carefully avoid to use them as output-arguments in functions (only objects are handled 'by reference').
Who has eagle eyes to spot my error?
Hi Klaus,
to copy the content of an array (and ONLY the content) you should use sth. like this:
Array1 = Array2.slice();
With Array1 = Array 2 you only create a second word for one and the same thing.
Hi Klaus,
Whow!
Is this obvious - or a speciality of JavaScript?
I grew up with Fortran, Assembler, Pascal, Visual Basic and the script language AutoHotKey. Used JS not extensively on webpages...
Anyway: Klaus, thank You very much for this insight!
