Dear friends,
I have a number of objects stored in an array.
It seems that the array does not point to the objects, but has copies of them.
The item in the array is only updated with array[index].prop notation, not with the object.prop notation.
It would be possible to always use the array[index].prop notation for an update of items, but I want to understand, why the other method does not work. And of course there should be no copies...
var objArray = [oObject0, oObject1, oObject2];
function oObjTpl (name, scheme, start, incr, current, decimals, items) { // 'prototype' definition
this.Name = name;
this.Scheme = scheme; // numermic | roman | ROMAN | text
this.Start = start; // start value
this.Incr = incr; // increment, may be a formula string
this.Current = current; // Last inserted value or item
this.Decimals = decimals; // relevant only for numeric scheme
this.Items = items; // array of list items, relevant only for text scheme
}var items0 = ["one","two", "three", "four", "five", "six", "zz", "seven", "eight", "nine", "ten"];
var oObject0 = new oObjTpl ('CountingEN', 'text', 1, 1, undefined, undefined, items0);
var oObject1 = new oObjTpl ('oObject1', 'numeric', 17, -1, undefined, 0, undefined);
var oObject2 = new oObjTpl ('oObject2', 'roman', 1, 1, undefined, 0, undefined);// replace the zz by soemething else
oObject0.Items[6] = "AAAA"; // this does not update objArray
$.writeln (objArray[0].Items);objArray[0].Items[6] = "BBBB"; // this updates objArray
$.writeln (objArray[0].Items);oObject0.Items[6] = "CCCC"; // update of objArray effective in next run
When running the script 3 times I get this console output:
one,two,three,four,five,six,zz,seven,eight,nine,ten
one,two,three,four,five,six,BBBB,seven,eight,nine,ten
Result: undefined
one,two,three,four,five,six,CCCC,seven,eight,nine,ten
Result: undefined
Result: undefined
Thanks Apollo, but this did not do the trick.
But I have found that the order of definitions is crucial here. The following works as intended:
...function oSeries (name, scheme, start, incr, current, decimals, items) { // 'prototype' definition
this.Name = name;
try in function oObjTpl "return this" in the end.
Regards
Apollo
this.Name = name;
//return this; // ahs no effect
var oSeries_0 = new oSeries ('CountingEN', 'text', 1, 1, undefined, undefined, items0);
var oSeries_1 = new oSeries ('oSeries_1', 'numeric', 17, -1, undefined, 0, undefined);
var oSeries_2 = new oSeries ('oSeries_2', 'roman', 1, 1, undefined, 0, undefined);var aSeries = [oSeries_0, oSeries_1, oSeries_2];
var a1 = aSeries[2].Scheme; // roman
$.writeln (a1);// replace the zz by octogon
oSeries_0.Items[6] = "AAAA"; // this does not update aSeries
$.writeln (aSeries[0].Items);aSeries[0].Items[6] = "BBBB"; // this updates aSeries
$.writeln (aSeries[0].Items);oSeries_0.Items[6] = "CCCC"; // update of aSeries effective in next run
$.writeln (aSeries[0].Items);/*
one,two,three,four,five,six,AAAA,seven,eight,nine,ten
The order now is: set up the objects and then set up the array of objects.
