I've recently setup and configured a server farm running Windows Server 2012 and ColdFusion 10 Enterprise. I have a cluster created using named instances (not cfusion, though I find it curious that CF10 will allow you to cluster the cfusion instances now - but that presents problems - a different discussion later) anyhow.
I began with Sticky Sessions enabled on the Cluster and it worked as expected, I then wanted to turn off Sticky Sessions so that the applications would enjoy a seemless failover. Unchecking the box on the Cluster manager, restarting IIS and CF, had no effect. Sticky was still, well, sticky. An examination of the cluster.xml revealed that the <stickysession> node was set to "false" but workers.properties still had sticky set to true, so I edited workers.properties, saved, restarted and voila the cluster was no longer sticky.
Now here's where things get weird. I get a call from a member of my team, a user is losing their session and getting logged out. A test was conducted, we dumped the session to the browser and began refreshing the page with a delay between refreshes (F5 key down, F5 key up) and the session id stayed the same, as expected. So I held down F5 for a few seconds, bombarding the server with page requests, and suddenly the sessionid began cycling all sorts of randomness! Going back to a delayed pulse of refreshes, session stayed replicated, holding refresh again within seconds we get a constantly changing sessionid.
The reason the user was losing their session was because the application is a heavily ajax based system, there are many ajax calls happening whenever the user manipulates objects on screen (it's a CMS) so naturally these occur very fast (akin to holding refresh key down)
ColdFusion 10 Update 10 10,0,10,284825
Tomcat 7.0.23.0
Java Version 1.7.0_15
OS Version 6.2
Thanks for any ideas/help. Apologies for the short story.
We are experiencing this exact problem using ColdFusion 11. I wrote a test page that makes 100 ajax requests at a given interval, alternating between a post and a get. You can reduce the interval setting in the java-script and eventually the ajax calls will start returning different session ids.
We are using latest CF11 running on windows 2012 R2 Standard with an IIS front end site. All current updates applied. Clustering and instancing have been set up per ColdFusion documentation to use session replication but not sticky sessions.
Any suggestions would be great!
ColdFusion 11,0,05,293506
Java 1.8.0_25
OS 6.2
i also have a similar situation, brand new install, 2 servers, 2 instances on each (cfusion and cluster_member)
a cluster set up on each server with the local member and the remote member.
session replication doesn't seem to work at all on CF11 with multiple servers, unfortunately i see nothing in any logs indicating any issues and obviously am not alone.
Vestige mentioned what first came to my mind: logs. Perform a test where you log te session cookies. Then the question is, are the newly generated sessions emerging from multiple instances in the cluster or from just one?
