I am unable to authorize to a new computer because the ebook Vendor option window will not open to allow me to select the correct vendor (BooksAMillion). Thus Adobe ID stays in space of ebook Vendor.
Which winodw are not open exactly? Help > Computer authorize?
On the Authorization window where you have to put in 1) ebook Vendor, 2) Adobe ID, and 3) Password. The #1 ebook Vendor option should open where you can scroll down and select stores where bought ebook from.
And the Scroll down option was not open?
Same problem on Windows 10. eBook Vendor is greyed out and there is no pull-down to select another (Overdrive in my case). Any help with this?
Close all applications. | |
Choose Start > Run. | |
In the Open text box, type regedit and then press Enter. The Registry Editor opens. | |
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept | |
Select the Adept key. | |
Choose File > Export. | |
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save. | |
Right-click the Adept key and choose Delete. | |
In the Confirm Key Delete dialog, click OK. | |
Close the Registry Editor. | |
Open Adobe Digital Editions and reauthorize. |
