CF10 Update 20 - Can not install
Jun 28, 2016 Jun 28, 2016
Working a Window 2008 R2 (64 bit) VM machine running ColdFusion 10. ColdFusion is installed to the D:\ drive. I Have been trying to patch to Update for the last 10 days.
Initially I was able to update from 19 to 20 via the cfusion instance. Patching all 7 instances at once. The next day I decided to go and double check all the instances. I noticed that one of the instances was not updated. Let's call that one "cTest".
I had to uninstall Update 20 for all of the instances to try and update cTest. Then I started getting 500 errors for cTest when trying to connect to the site or the CF Administrator for on port 8508.
I done the following to try resolve this issue.
  1. Rolled back the update from 19 to 17. Then restarted the server. Still having issues. The service restarts. But, CF administrator displays a 500 Error message.
  2. Port scanned to make user there was no conflicts.
  3. Manually downloaded the JAR file from the Adobe site. I did this because I noticed that the file was try to extract from my account and not via the service account for the CF server.
  4. I opened a DOS window with "Run as Administrator" and manually tried to invoke the installer via java -jar hotfix_020.jar this seemed to install properly. But, the service fail to start and I started getting "Error 2" messages about the service.
  5. I have checked ownership of hotfix_010.jar. I made sure that it was set for the right owner invoking the file. And, the file permissions.
The last update try was just for cTest to be updated from 17 to 20. Here are logs for that:
Adobe_ColdFusion_10_Update_20_Install_06_28_2016_12_42_13.log
__________________________________________________________________________
Tue Jun 28 12:42:38 MDT 2016
Free Memory: 216592 kB
Total Memory: 316928 kB
4 Command Line Args:
0:  -i
1:  silent
2:  -f
3:  D:\ColdFusion10\cTest\hf-updates/hf-10-00020.properties
java.class.path:
    D:\ColdFusion10\cTest\hf-updates/hotfix_020.jar
ZGUtil.CLASS_PATH:
sun.boot.class.path:
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\resources.jar
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\rt.jar
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\sunrsasign.jar
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\jsse.jar
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\jce.jar
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\charsets.jar
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\jfr.jar
    D:\Program Files\Java\jdk1.8.0_51\jre\classes
java.ext.dirs:
    D:\Program Files\Java\jdk1.8.0_51\jre\lib\ext
    C:\Windows\Sun\Java\lib\ext
java.version                  == 1.8.0_51 (Java 1)
java.vm.name                  == Java HotSpot(TM) 64-Bit Server VM
java.vm.vendor                == Oracle Corporation
java.vm.version               == 25.51-b03
java.vm.specification.name    == Java Virtual Machine Specification
java.vm.specification.vendor  == Oracle Corporation
java.vm.specification.version == 1.8
java.specification.name       == Java Platform API Specification
java.specification.vendor     == Oracle Corporation
java.specification.version    == 1.8
java.vendor                   == Oracle Corporation
java.vendor.url               == http://java.oracle.com/
java.class.version            == 52.0
java.library.path             == D:\Program Files\Java\jdk1.8.0_51\jre\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Program Files (x86)\Java\jre1.8.0_91\bin;C:\Program Files\PHP\v5.3;C:\Program Files\PHP\v5.3;C:\Perl64\site\bin;C:\Perl64\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\idmu\common;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;D:\Program Files\ANT\bin;D:\php;;;D:\ColdFusion10\cTest\lib;D:\ColdFusion10\cTest\jintegra\bin;D:\ColdFusion10\cTest\jintegra\bin\international;D:\ColdFusion10\cTest\lib\oosdk\classes\win;.
java.compiler                 == null
java.home                     == D:\Program Files\Java\jdk1.8.0_51\jre
java.io.tmpdir                == C:\Users\INPNRP~1\AppData\Local\Temp\
os.name                       == Windows Server 2008 R2
os.arch                       == amd64
os.version                    == 6.1
path.separator                == ;
file.separator                == \
file.encoding                 == Cp1252
user.name                     == CFRunAccount
user.home                     == C:\Users\CFRunAccount
user.dir                      == D:\ColdFusion10\cTest\bin
user.language                 == en
user.region                   == null
Installed Feature(s) Multi, J2EE of Adobe ColdFusion 10 Update 20
Install Begin: JUNE 28, 2016 12:42:01 PM MDT
Install End: JUNE 28, 2016 12:42:37 PM MDT
Installed by InstallAnywhere 17.0 Premier Build 5123
User Interactions
Summary
Installation: Unsuccessful.
350 Successes
0 Warnings
5 NonFatalErrors
7 FatalErrors
Action Notes:
Moving files failed:: Failed to back up the previous hotfix files. Retry installation after ensuring that the server is not running or files are not locked by the server.
Failed to copy hotfix files:C:\Users\CFRunAccount\844358.tmp\dist\cfusion: Failed to copy the hotfix files to the target location. Retry installation after ensuring that the server is not running or files are not locked by the server.
Failed to delete directory: Ensure that the server is not running or files are not locked by the server.
Install Log Detail:
Check Disk Space:         D:\ColdFusion10
                          Status: SUCCESSFUL
                          Additional Notes: NOTE - Required Disk Space:73,318,334 Bytes Free Disk Space:-1 Bytes
Get Registry Entry:       Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DevDiv\VC\Servicing\11.0\RuntimeMinimum
                          Value Name: Version
                          Status: SUCCESSFUL
                          Value Name: Version
                          Status: SUCCESSFUL
Custom Action:            com.adobe.utils.HotFixProps
                          Status: SUCCESSFUL
Get Registry Entry:       Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Adobe\Install Data\Adobe ColdFusion 10
                          Value Name: CFMXRoot
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.customrule.DocRootValidate
                          Status: SUCCESSFUL
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.customrule.ReadXML
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.action.UpdatableInstances
                          Status: SUCCESSFUL
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.action.LoggableInstance
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.action.VersionCheck
                          Status: SUCCESSFUL
Modify Text File - Single File:   New File \cfhotfix.txt
                          Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 Jetty Service
                          Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 .NET Service
                          Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 ODBC Server
                          Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 ODBC Agent
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.action.ServersStartStopAction
                          Status: SUCCESSFUL
Stopping Windows Service: ColdFusion 10 Application Server $STARTSTOP_SERVER_NAME$
                          Status: SUCCESSFUL
Execute Command:          D:\ColdFusion10\cTest\bin\coldfusion stop
                          Status: SUCCESSFUL
Custom Action:            com.adobe.utils.InstallDateTime
                          Status: SUCCESSFUL
                          Status: SUCCESSFUL
Install Directory:        C:\Users\CFRunAccount\844358.tmp\
                          Status: SUCCESSFUL
                          Additional Notes: NOTE - Directory already existed
Delete File:              Source:cfhotfix.txt
                          Status: SUCCESSFUL
                          Additional Notes: NOTE - Source file cfhotfix.txt does not exist.
Install File:             C:\Users\CFRunAccount\844358.tmp\update.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\updates.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cf-bootstrap.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cf-init-run.sh
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cf-startup.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfcompile.bat
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfcompile.sh
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfinfo
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfinfo.bat
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfinfo.sh
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\coldfusion.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\coldfusionsvc.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\msvcr100.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\jetty\cfjetty
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\auth-ehcache.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\axis2\httpcore-4.0.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\cf-logging.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-codec-1.6.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-collections-3.2.2.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-logging-1.1.3.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-logging-api-1.1.1.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-net-3.4.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ehcache-core-2.6.6.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-common.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-core.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-opt.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-proxy.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-remoting.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\fluent-hc-4.5.2.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpclient-4.5.2.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpclient-cache-4.5.2.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpcore-4.4.4.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpmime-4.5.2.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6core.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6http.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6swing.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6util.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\jai_codec.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\jai_core.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\jai_imageio.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\log4j.properties
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\macromedia_drivers.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\mail.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\mysql-connector-java-commercial-5.1.17-bin.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\neo-drivers.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\neo_updates.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\postgresql-9.3-1101.jdbc41.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\threaddump.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\bootstrap.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\catalina-tasks.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\catalina.bat
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\catalina.sh
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\daemon.sh
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\service.bat
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\setclasspath.bat
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\setclasspath.sh
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\tomcat-juli.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\tomcat-native.tar.gz
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\annotations-api.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\ant-launcher.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\ant.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina-ant.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina-ha.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina-tribes.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\ecj-4.4.2.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\el-api.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jasper-el.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jasper.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jsp-api.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jta.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\servlet-api.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-api.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-coyote.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-dbcp.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-i18n-es.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-i18n-fr.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-i18n-ja.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-jdbc.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-util.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\wsconfig.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\bin\coldfusion.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\bin\coldfusionsvc.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\bin\msvcr100.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\cfperfmon_10.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\cfregistry.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\CFWindowsLogin.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\CFXNeo.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\DDJDBCAuth05.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\NeoUUID.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\PerfmonClient.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\TypeViewer.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\bin\mfc100.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\CheckConfig.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\com2java.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\com2java.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\com2javacmd.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\install_license.bat
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\CheckConfigEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\com2javaEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\ntvauthEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\ntvinvEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regjvmcmdEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regjvmEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regprogidEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regtlbEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\setdllhostEnglishResourceDll.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\java2com.bat
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\jintmk.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\ntvauth.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\ntvinv.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\ntvocx.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regjvm.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regjvmcmd.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regprogid.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regtlb.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\setdllhost.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\jintegra_changelist.txt
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\version.txt
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\lib\jintegra.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\lib\TypeViewer.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\updates\chf10000020.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\administrator.cfc
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\customtags\l10n.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\runtime.cfc
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\security.cfc
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\aboutcf.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\appinstaller\uninstall.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\Application.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\Application.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\deploywizard.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\security.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiveSummary.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_applets.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_archivesummary.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_cfdirectorymappings.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_cfxtags.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_datasources.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_eventgateways.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_filelocations.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_information.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_pdfservice.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_restservices.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_scheduledtasks.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_settings.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_todolist.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_veritycollections.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archivewizard_page_webservices.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\buildwizard_page_buildstatus.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\buildwizard_page_pickfile.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\controludfs.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\deploywizard_page_locations.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\deploywizard_page_status.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\deploywizard_page_summary.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\l10n.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\l10n_testing.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\resources\archives_en.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\resources\settings_en.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\db2.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\derbyClient.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\informix.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\j2ee.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\jdbcodbc.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\mysql5.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\mysql_dd.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\odbcsocket.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\oracle.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\postgresql.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\sqlserver.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\sybase.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\udflibrary.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\debugging\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\applets.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\cfx.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\corba.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\webservices.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\filedialog\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\header.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\homepage.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\include\udflibrary.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\j2eepackaging\editarchive.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\j2eepackaging\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\login.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\login_migration.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\logviewer\_searchloglogic.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\logviewer\_searchloglogic_other.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\monitor\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\monitor\launch-monitor.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\reports\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\reports\_report.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\scheduler\probes.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\scheduler\scheduleedit.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\scheduler\scheduletasks.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\cfadminpassword.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\useredit.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\userpassword.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\_fileoptions.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\settings\memoryvariables.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\settings\server_settings.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\settings\version.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\setup\migrationcf8_import.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\setup\migrationcf9_import.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\missing_template_error.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\request_timeout_error.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\request_timeout_error.htm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\secure_profile_error.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\Application.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\download.cfc
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\download_info.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\error.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\index.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\info.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\installer_input.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\overwrite.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\task\checkupdates.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\uninstall.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\_settings.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\_sysinfo.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\_updates.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\classes\cfapplets.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\componentutils\cfcexplorer.cfc
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\gettingstarted\community\webroot\shared\error.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfajax.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfcalendar.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfgrid.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfwebsocketCore.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\ext\map\GMapPanel3.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\ext\map\mapiconmaker.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\FCKeditor\fckeditor.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfajax.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfcalendar.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfgrid.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cflayout.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfmap.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfwebsocketChannel.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfwebsocketCore.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\map\marker.png
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\skins\smartphone-skin.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\skins\tablet-skin.xml
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\uploadfile.css
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\smp\StrobeMediaPlayer.js
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\cftags\META-INF\taglib.cftld
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\debug\dockable.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\exception\coldfusion\filter\FormValidationException.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\exception\detail.cfm
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\lib\cfmx_bootstrap.jar
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\admin\mmcslx.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\admin\openssl600.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\admin\swcla.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\openssl600.dll
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\swagent.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\swsoc.exe
                          Status: SUCCESSFUL
Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\swsocw.exe
                          Status: SUCCESSFUL
Delete Folder:            Source:_win32
                          Status: SUCCESSFUL
Move Folder:              Destination: C:\Users\CFRunAccount\844358.tmp\dist\cfusion
                          Status: SUCCESSFUL
Install Directory:        D:\ColdFusion10\
                          Status: SUCCESSFUL
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest\lib\updates\chf10000017.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup\lib\updates\chf10000017.jar
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpclient-4.3.5.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpclient-4.3.5.jar
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpclient-cache-4.3.5.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpclient-cache-4.3.5.jar
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpcore-4.3.2.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpcore-4.3.2.jar
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpmime-4.3.5.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpmime-4.3.5.jar
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/runtime/lib/ecj-P20140317-1600.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/runtime/lib/ecj-P20140317-1600.jar
Custom Action:            com.adobe.utils.Logger
                          Status: SUCCESSFUL
                          Status: SUCCESSFUL
                          Status: SUCCESSFUL
                          Status: FATAL ERROR
                          Additional Notes: FATAL ERROR - Failed to copy the hotfix files to the target location:D:\ColdFusion10\cTest
                                            FATAL ERROR - D:\ColdFusion10\cTest\bin\coldfusion.exe (The process cannot access the file because it is being used by another process)
                          Status: ERROR
                          Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpclient-4.3.5.jar
                                            ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpclient-4.3.5.jar
                          Status: ERROR
                          Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpclient-cache-4.3.5.jar
                                            ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpclient-cache-4.3.5.jar
                          Status: ERROR
                          Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpcore-4.3.2.jar
                                            ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpcore-4.3.2.jar
                          Status: ERROR
                          Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpmime-4.3.5.jar
                                            ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpmime-4.3.5.jar
                          Status: ERROR
                          Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/runtime/lib/ecj-P20140317-1600.jar
                                            ERROR - Unable to delete file: D:\ColdFusion10\cTest\runtime\lib\ecj-P20140317-1600.jar
Custom Action:            com.adobe.ia.action.InstallData
                          Status: SUCCESSFUL
Custom Action:            com.adobe.utils.XMLUpdate
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.action.UpdateConfigs
                          Status: SUCCESSFUL
Execute Command:          regsvr32.exe /s D:\ColdFusion10\cTest\lib\TypeViewer.dll
                          Status: SUCCESSFUL
Install Directory:        D:\ColdFusion10\cTest\hf-updates\hf-10-00020\uninstall\
                          Status: SUCCESSFUL
Install Uninstaller:      Adobe ColdFusion 10 Update 20(Install All Uninstaller Components)
                          Status: SUCCESSFUL
                          Status: SUCCESSFUL
Modify Text File - Single File:   New File D:\ColdFusion10\cTest\hf-updates\hf-10-00020\uninstall\installvariables.properties
                          Status: SUCCESSFUL
Custom Action:            com.adobe.ia.action.StartServersAction
                          Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 Jetty Service
                          Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 .NET Service
                          Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 ODBC Server
                          Status: SUCCESSFUL
Starting Windows Service: ColdFusion 10 ODBC Agent
                          Status: SUCCESSFUL
1.7K
Adobe Employee ,
Can you please share your details on cf.install@adobe.com. We will get in touch with you to get this fixed.
Adobe Employee ,
Jul 11, 2016 Jul 11, 2016
Using a 32 bit version of java to apply update on 64 bit ColdFusion and vice versa causes this issue.
Jul 13, 2016 Jul 13, 2016
Rahul_u, I'm getting this same error on ColdFusion 11 running update 9 from the CF Administrator.  I am running a 64 bit version of Java & CF 11.  Any ideas?
Adobe Employee ,
Can you please try installing the update manually using Coldfusions built in java.
Uninstalled the update.
Download the update 9 from https://cfdownload.adobe.com/pub/adobe/coldfusion/11/hotfix_009.jar
Place the hotfix_009.jar in ColdFusion11\jre\bin
Launch Command prompt as administrator, and navigate to C:\ColdFusion11\jre\bin
Run the command: C:\Coldfusion11\jre\bin> java -jar hotfix_009.jar and follow the online screen instructions to complete the update.
Oct 04, 2016 Oct 04, 2016
I successfully installed CF 10 hotfixes 19, 20 and 21 using this manual command line method. It was the only method I had success with. Thank you.
Feb 14, 2019 Feb 14, 2019
Thank you, this worked for me.
Documentation
