Hi Peter!
In his last post (in thread :
http://tinyurl.com/6hbdlw),
Roger N gives a 3 steps procedure to work arround this issue (see
below an extract from Roger's last post) :
Roger N [Senior Member] 08/15/2006 06:57:42 AM
In
whthost.js:
1) edit the function
writeBookItems() as described.
2) remove the
width property from the
TocWriteFixedWidth() function,
3) remove the single
<nobr> and
</nobr> from the string found in the function
WriteAnItem().
To wrap the book titles, you would do the same for the
WriteBook() function, and insert the script replacement
mentioned above (in the first post) wherever it goes for books (ok,
I'm getting lazy again).
I followed these 3 steps and here's what I've got :
Nothing significant until step 3 was done (I checked results
after each step by reloading index.htm file);
After step 3: Topics titles in TOC were looking fine and were
wrapped! YES!
But... TOC synchronization stopped working.
I must also add that I didn't succeed with
Books Titles wrapping because I didn't know how to modify
properly the
WriteBook() function.
Rgds,
Jean Laurier
p.s.: There is no
whthost.js file when generating a FlashHelp output! So I'm
still searching a solution for that issue!
