Hi guys. My project has 2 help slides and we can navigate between them, (they are slides 2 and 3 on the project). Slide 3 can be accessed from any of the other slides, and from there the user can decide which aspect of help they need. My problem is that I would like the user to be able to return to the slide from which they accessed the help. Obviously, a simple button with a 'return to next slide' action is no good, as if they access both help slides and then try to return they are in the 'help' loop. So my question is "how do I do that?"
As always, all help greatly appreciated.
Robbie
Here is the link: Navigation Help Slides - Captivate blog
Indeed, you cannot use the system variable cpInfoLastVisitedSlide because that could get the user in a loop. You'll have to store the value the slide from where the user navigates, in a user variable (will label it v_last), to 'fix' it. I would recommend to use the same event that triggers the navigation to the help slides to execute that command, which means you'll have a standard advanced action like this:
The Success event of the Return button on both Help slides will then trigger this action:
Depending on the setup of slides, maybe you'll need to add Continue to that return action.
Hi Lilybiri and many thanks. This is somewhere outside my skill set and so I'll have to try to get up to speed on variables and advanced actions - do you know if there are any tutorials out there to get me started?
Again many thanks - Robbie
You are totally new to variables and Advanced actions? OK, will try to write out a short blog post with the work flow you need and be back with the link when I'm ready. It will be too long to post here.
Lilybiri - many thanks indeed that will be extremely helpful. I look forward to receiving the link.
Robbie
Thanks Lieve, I'm not ignoring you here I just am concentrating on getting something built for the client. I'll have a go at the process next week. Your help is much appreciated! Robbie
