Show 10 replies
1. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
fyz123 Jun 8, 2008 1:25 AM (in response to Jenn_MM)Hi,
I think your doc file is corrupt, too. You can try a utility called Advanced Word Repair to repair your Word document. It works rather well for my corrupt Word documents.
Alan -
2. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
bawd Jun 10, 2008 3:55 AM (in response to Jenn_MM)Did you try deleting the .rtf? (Close project, open Explorer, browse to the appropriate .rtf file and delete it - RH produces a new one when the project is next opened, usually without the untraceable error if there was one!)
Brian -
3. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
Jenn_MM Jun 11, 2008 7:12 AM (in response to Jenn_MM)Hmmm...interesting...that seemed to fix some of my problems but not all of them. Here's another puzzler---if compile the project outside of RoboHelp (in Help Compiler Workshop). all the f1 links work. So it must be something RH is doing to the file during the compiliation process. That's all I can figure anyway. So I'm going to try this as a workflow and see if it works:
1. Work on the project in RH for Word.
2. Compile in HCW.
4. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
Peter Grainge Jun 11, 2008 7:21 AM (in response to Jenn_MM)Are you fully patched? 1 and 2.
5. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
Jenn_MM Jun 11, 2008 1:09 PM (in response to Jenn_MM)Thanks! That did the trick! Although I wish I'd known about it before I went through the whole CSI routine with my project tho... : - ( -
6. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
Peter Grainge Jun 11, 2008 10:37 PM (in response to Jenn_MM)Set it to autoupdate.
7. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
wgmeisheid Jun 12, 2008 4:24 AM (in response to Peter Grainge)Peter, you mentioned two updates. I cannot do online updates here at work. I am in an offline secure environment, and I only saw one update on the RoboHelp Update page (7.02). Did I need to find and apply 7.01 or some other update first? It did not alert me to anything when I applied it.
At the installation at home office, the Adobe auto-update only found 7.02. My installed version in both places is 7.0 Build 145 and I launched the Help|Updates from RoboHelp Explorer in RoboHelp for Word.
Thanks in advance. -
8. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
Peter Grainge Jun 12, 2008 4:43 AM (in response to Jenn_MM)You can download the updates to a memory stick or CD.
http://www.adobe.com/support/robohelp/downloads.html
9. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
Jenn_MM Jun 13, 2008 8:03 AM (in response to Jenn_MM)I checked my settings and auto update was selected but obviously never occurred. The app prompted me to register the product a couple of times--maybe I need to do that in order to get the fixes. -
10. Re: Robohelp for Word 7.0--WinHelp 4.0--Corrupt Word File--how to fix??
Peter Grainge Jun 13, 2008 9:36 AM (in response to Jenn_MM)I think auto update might not happen if your profile does not have admin rights.
