I'm concerning to subscribe Adobe CC, But, I've got problem with Photoshop CC' shortcuts.
http://forums.macrumors.com/showthread.php?t=1596253 here is the same problem as I experienced.
I completely reinstalled Mac OS X 10.9 DP1, It still messed up.
So, I tried to move ~/Library/Preferences folder to Desktop and works ok. But, I changed System Preference - Keyboard - Shortcuts,
It happened again.
I think that this problem is come from mismatching system's shortcuts preferences.
Would you patch this problem?
Thanks.
Here are a few resources that may help:
http://helpx.adobe.com/photoshop/using/sync-settings.html
http://blogs.adobe.com/crawlspace/2013/06/updatingupgrading-to-photoshop-cc-faq.html#help
If you're running a beta OS, then you can expect problems. Make sure you report this issue to Apple on the Seed forum.
Ever since the latest Mavericks DP and Photoshop CC updates, all of my Photoshop shortcuts were broken, and displayed as this: ⌘â‰
Frustrating, to say the least… Even trying to reinput them manually didn't work. However, I think I've discovered the source of the problem and a means to fix it that I mean to share with anyone else experiencing this horrible glitch:
Check your Input Sources for your keyboard and reset it to U.S. Mine was set to Romaji via Kotoeri (Japanese).
Hope this works for you. If it doesn't, try entering in some custom keyboard shortcuts before rebuilding the defaults (not sure it made a difference, but that is what I did to test it beforehand). Oh, and don't switch your keyboard input to anything else other than U.S. while or before opening Photoshop CC.
It's quite possible that other keyboard Input Sources still work, but I have not tested. U.S. (English) worked for me. Please post here your findings as well.
this worked for me: (~/Library/Preferences/Adobe Photoshop CS6 Settings)
Go to ~/Library/Preferences/Photoshop CC/
Thanks, bud! This worked for me, but I had to make sure to:
1.) Close Photoshop
2.) Delete Adobe Photoshop CS6 Prefs.psp
3.) Make sure my keyboard was set to English - US
4.) Start up Photoshop, and voila
I never need to use Romaji ever, so this is fine for me!
It worked for me, as I had Romaji on! (step 1 to 3)
As soon as I switched to Australian keyboard, (not US as you suggested, and I didn't want to add any more keyboard) then opened Photoshop, it was fine.
Once I am in the Photoshop I can change the input source to Romaji and the shortcut keys are not affected.
I have just uninstalled and reinstalled all of my Adobe softwares via Creative Cloud. Problem solved.
HEY GUYS,
PROBLEM IS RESOLVED FOR ME !!! IM SO RELIEVED !!!
THIS IS MY FIRST POST BECAUSE AFTER I SUCCEED FIXING THE PROBLEM I COME STRAIGHT HERE TO SHARE!!!
THIS IS WHAT I DID:
QUIT PHOTOSHOP -> OPEN FINDER -> TYPE TO SEARCH : Default Keyboard Shortcuts.kys -> RUN THE FILE , IT WILL OPEN PHOTOSHOP AND ASK YOU IF YOU WANT TO SAVE THE CURRENT SHORTCUTS, CLICK DON'T SAVE -> VOILA !!!
I'VE QUIT AND OPENED PHOTOSHOP SEVERAL TIMES TO MAKE SURE. AND IM USING VIETNAMESE KEYBOARD INPUT, NO PROBLEM AT ALL SWITCHING TO OTHERS.
THE SHORTCUTS ARE TRULY BACK !!!
BUT I HAVENT TRIED TO RESET THE PC.
SO DO THE SAME AND LET ME KNOW IF IT WORKS FOR YOU !!!
HOPE THIS HELPS XOXO
Though, I believe there is a new problem, with Your Caps Lock-key this time
Thanks for sharing this but it's still not working for me. Not only are my Photoshop CC shortcuts not working, Illustrator CC has the same problems too. I'm using Mavericks as well.
I just posted a similar problem here:
Re: Photoshop CS6 issue with shortcuts and my keyboard after upgrade from CS5
with Photoshop CS6 and Yosemite (both clean installs). This is NOT affecting InDesign, Illustrator or Acrobat, only Photoshop. I tried every suggestion in this thread without luck. Guess I'm going to resort to reinstalling as it's impossible to work with shortcuts.
I found something that seems to have fixed it for me.
1) Edit > Keyboard Shortcuts
2) Under the Set: dropdown on the top right, choose "Photoshop defaults"
3) You will get a warning about saving or losing. Choose "Don't Save".
4) OK
This reset the shortcuts to defaults and seems to work no matter whether I'm in Japanese or US input mode.
Trying to make this work, but PS keeps hanging when I quit after shortcut changes. The other issue is that this keyboard shortcut dialog should be in the Preferences pane! Poor UI/UX.
Moving to Photo shop
Regards
Rajashree
Adobe, Please advise how to fix this!
Kiperline | Shop Modern Tech and Powerful Electronics.
Find cutting edge electronics for an amplified lifestyle.
Convenient and performative technology, browse portable monitors, keyboards, laptops, and more.
Kiperline Wireless Connection Portable Monitor offers versatile connectivity with a Wireless Projection option to connect the monitor to your device cable-free.
