Locked
Turn on Adobe Animate AIR 20.0 for Android Compile Logging
Jul 07, 2016 Jul 07, 2016
If the publish fails you'll see a dialog box with the errors. But in the case you have a massive compile log it won't fit in the dialog box.
Is there a way to turn on logging when compiling/publishing for Android?
Apparently, Flex has a config options.
Adobe Flex 4.6 * Configuration file syntax
One config option might turn on logging.
Adobe Flex 4.6 * Compiler logging
How is the Air compiler logging turned on?
I tried running Animate.exe from the command-line but that doesn't show standard output/errors.
The flex sdk docs suggest something like this.
<?xml version="1.0"?>
<flex-config>
  <show-binding-warnings>false</show-binding-warnings>
</flex-config>
Which would be placed in:
C:\Program Files\Adobe\Adobe Animate CC 2015\Common\Configuration\ActionScript 3.0\flex_sdk\4.5.0\frameworks\flex-config.xml
No effect.
Is there a way to suppress warnings so that I can see just the errors?
~Tim Graupmann
Development
286
