Hi, G
Looks like Rick has covered the main points. I would only add
that the improvement in RH 7 which Colum mentioned has mostly to do
with *correctly* importing all the extra support files that
Captivate 2 and 3 create. These include those (.js, .htm., .swf,
and skn.swf) you mentioned. Because of the release dates, RH 6 did
not know how to handle the newer Captivate files. So, it took some
tweaking to make it work.
If it works for you now, then terrific. If you are still
having problems, I wrote an article for the Adobe Developer Center
which discusses this very issue.
Tutorial #4 in particular might be relevant as far as
workarounds when using RoboHelp 6
http://www.adobe.com/devnet/captivate/articles/cp_rh_integration_print.html
So, it works in RH 6, but MUCH better in RH 7
Hope you can upgrade soon. There are many more fine features.
Thanx
John
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Newport, Oregon
