hello, when i install adobe animate I get the following error:
Exit Code: 146
-------------------------------------- Summary --------------------------------------
- 2 fatal error(s), 0 error(s), 1 warnings(s)
FATAL: Error (Code = 146) executing in command 'MoveDirectoryCommand' for package: 'AdobeAnimate15.2-mul', version:15.2.0.69
FATAL: Error occurred in install of package (Name: AdobeAnimate15.2-mul Version: 15.2.0.69). Error code: '146'
WARN: Failed to move directory 'C:\adobeTemp\ETR4FA9.tmp\1\mul\AppFiles' to 'C:\Program Files\Adobe\Adobe Animate CC 2015.2'
help?
is for Animate, no Photoshop & Illustrator.
another option?
It can apply to any CC product
I do not understand what I have to do
You could cite what they should do to fix it?
UP
Can you see if the steps given in this different problem can help?:
Re: Cant install air sdk into animateCC
My hope is that there is an issue with creating a folder that seems to have a file extension, and if you do the same steps it may solve this problem too.
Did you look inside the Adobe folder?
It is not here
other solution? I need it
I just upgraded adobe muse and I got the same error WTF!
Moved this post to a more appropriate forum. The experts here should be able to assist you well.
