returning encoded json
Jul 11, 2016 Jul 11, 2016
I am using the bootstrap framework for my form validation but I also am trying to trigger a success callback using Ajax and Coldfusion.
CFMAIL gets processed OK in the mail.cfm file that I am using, however I also need the mail.cfm file to respond an encoded JSON, such as { "result": "ok" } or { "result": "error" }.
Currently it doesn't respond anything (The current response is empty) therefore $.ajax() isn't triggering the success callback.
Any ideas?
<script>
// <![CDATA[
$(document).ready(function() {
    $('#addSurveyForm').formValidation({
  // I am validating Bootstrap form
        framework: 'bootstrap',
        // Feedback icons
        icon: {
            valid: 'glyphicon glyphicon-ok',
            invalid: 'glyphicon glyphicon-remove',
            validating: 'glyphicon glyphicon-refresh'
  // List of fields and their validation rules
        fields: {
                validators: {
                    notEmpty: {
                        message: 'The name is required and cannot be empty'
            }, // End of name
  } // End of fields
})  // End of validating form
   .on('success.form.fv', function(e) {
        // Prevent form submission
        e.preventDefault();
        // Some instances you can use are
        var $form = $(e.target),        // The form instance
            fv    = $(e.target).data('formValidation'); // FormValidation instance
        // Send all form data to back-end
        $.ajax({
            url: 'mail.cfm',
            type: 'POST',
            data: $form.serialize(),
            dataType: 'json'
  .done(function(response) {
            // Clear the form
            $form.formValidation('resetForm', true);
             // Show the message
            response.result === 'error'
                ? $('#alertContainer')
                    .removeClass('alert-success')
                    .addClass('alert-warning')
                    .html('Sorry, cannot send the message')
                    .show()
                : $('#alertContainer')
                    .removeClass('alert-warning')
                    .addClass('alert-success')
                    .html('Your message has been successfully sent')
                    .show();
}); // End of script
mail.cfm:
<cfmail>
</cfmail>
<cfset myStruct =
    { "result": "ok" }
<cfscript>
    result = serializeJSON(myStruct);
    writeOutput(result);
</cfscript>
222
What about just returning the text upon success?
$.ajax({
            url: 'mail.cfm',
            type: 'POST',
            dataType: 'json',
            success: function(response){
                 $('#contentDiv').html();
<div id="contentDiv">{ "result": "ok" }</div>
Advocate ,
Jul 12, 2016 Jul 12, 2016
Your mail.cfm module looks correct. What happens when you call it directly? I use something like FireBug to capture the request and then run it manually to check the results.
I'm guessing that your mail.cfm side is correct but the javascript side has something isn't being executed the way you think it is.
Documentation
