Hi, When I download the installer to download Creative Cloud, I run it as an administrator and nothing happens
Disable Firewall Temporarily.
Step 1 :
Open C:drive and navigate to C:\Program Files (x86)\ " Common Files" \Adobe.
Open Adobe folder and delete folders named Adobe Application Manager and OOBE.
Step 2:
Navigate to C:\Program Files (x86)\Adobe.
Open Adobe folder and if present delete Adobe Creative Cloud folder. [**important]
Unable to delete??? rename it to Adobe Creative Cloud-old.
Step 3 :
Press Windows button (located between Ctrl and Alt buttons) along with R button together at a time , you will get
...Copy link to clipboard
susend av and antimalware, too.
I Disable the Avast but it does not let me
right click the exe>click 'run as administrator' after suspending av and antimalware.
what do you see?
it does not open
using a browser that allows popups and cookies, contact adobe support during pst business hours by clicking here and, when available, click 'still need help', http://helpx.adobe.com/x-productkb/global/service-ccm.html
Right click on Creative Cloud setup and select Properties option ,
If Unblock button is listed , click on it and then try to install ..
I tried but not open
I removed avast and ALL adobe programs and created a new user account and not running
The problem is Adobe Creative Cloud Setup
Step 1 :
Step 2:
Step 3 :
Press Windows button (located between Ctrl and Alt buttons) along with R button together at a time , you will get a run command window.
Type in below command and hit 'Enter' key.
appdata
Then navigate to Local>Adobe.
Open Adobe folder and delete folders named AAMUpdater and OOBE.
Step 4 :
"" Make sure Adobe Creative Cloud is not listed under Control Panel > Program and Features list. ""
Click on the below link and download Adobe Application manager and install the same :
http://download.adobe.com/pub/adobe/creativesuite/cc/win/ApplicationManager10.0_all.exe
Once the installation process is completed, locate Adobe Application Manager launch icon on Desktop and double click on it .
It will start update process.
once it is completed, it shud launch Creative Cloud app.
If you still face same issue , try to install via Selective Startup from MSConfig.
