Adding New Map ID
Jun 13, 2008 Jun 13, 2008
I've noticed that since I've upgraded from robohelp 5x to version 7. The "Add New Map ID" button isn't available. It's visible but grayed out. Is this a bug? Has anyone else experienced this problem? I can't find anything on it in the adobe knowledgebase.
821
Explorer , Jun 16, 2008 Jun 16, 2008
I do not have access to RH7HTML right now, but I recall having a similar problem.
In fact, I recall that a number of Map ID buttons were greyed out. The solution to our problem was to select a specific map ID file, instead of the entry "All map IDs". That might only be relevant if you have multiple map ID files, but it may still be required even if you have only one file.
I guess that RH7HTML needs to know which file it should add the map ID to, and this algorithms might be buggy in the sense ...
Valorous Hero ,
Welcome to our community, Dirk
Can you please provide a screen shot? I'm assuming you are using RoboHelp HTML based on the forum category, but I'm not sure.
Thanks... Rick
I'm having the same exact issue, and Yes I am using HTML Help. I would be happy to provide a screen shot, but I'm not sure how to attach it.
Angela P.
Hi Angela
Try the link below:
http://www.freeimagehosting.net
Cheers... Rick
Edit Map IDs dialog
Please let me know if you're not able to see this image.
I guess that RH7HTML needs to know which file it should add the map ID to, and this algorithms might be buggy in the sense that it still requires this even when only a single map ID file is present.
Hope this helps.
PET3689 - Thank you! I changed the Map File selection to <Project Map File> and the new map id icon became available. Thanks for the tip!
Angela
Your tip worked for me too PET3689. Thanks!
RoboHelp Documentation
Download Adobe RoboHelp
